Question about Mitsubishi WD-52525 52" Rear Projection HDTV
2001 Mitsubsi FE640 Disc Brake Light staying on
  • 126 Answers
Is this a car or t.v . shad
Posted on Jun 21, 2008
I have a 2001 Ford Windstar minivan. Sometimes
bad brake light switch it is behind the brake pedal
Feb 15, 2010 | 2001 Ford Windstar
Honda civic ex 2001 parking brake light stays on then goes off
Replace rear brake pads. If that doesn't help, remove the plastic console around the parking brake lever and adjust the pull on the lever. It's probably so loose that it's trigger the light.
This is not normal, looks like someone accidentally drove several miles with the brake on.
Oct 05, 2009 | 2001 Honda Civic
Parking brake light stays on
If it's just the light that stays on, often that's a sign that your brake fluid is low.
Jun 15, 2009 | 2001 Hyundai Sonata
2001 brake pad replacement 2001 nissan quest
The hard part is pressing the caliper piston abck into the caliper so you can get the new, thicker pads over the rotor. A large C Clamp works best.
SECTION 206-03: Front Disc Brake 2001 Villager Workshop Manual
REMOVAL AND INSTALLATION Pads —Front Disc Brake Removal
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the front disc brake caliper bolts. torx bit. T20?
  1. Support the front disc brake caliper from the front strut and spring assembly using mechanics wire.
  1. Remove the front disc brake pads.
    1. Remove the outboard front disc brake pad.
    1. Remove the inboard front disc brake pad.
Installation
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure the master cylinder reservoir does not overfill and spill brake fluid while retracting the front disc brake caliper piston.
    NOTE: It is necessary to fully retract the front disc brake caliper piston in the bore before installing the front disc brake pads.
    Install the front disc brake pads.
    1. Install the inboard front disc brake pad.
    1. Install the outboard front disc brake pad.
Caution. The outer pads are left and right. put left on driver side.
  1. Position the front disc brake caliper on the front-wheel knuckle and install the brake caliper pin bolts.
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif WARNING: It is necessary to depress the brake pedal several times to position the front disc brake caliper piston before driving the vehicle.
Apr 23, 2009 | 2001 Nissan Quest
Brake lights stay on 2001 chevy s 10
There is a brake light swich along the brake peddle that need's to be adjusted. Quick and easy fix.
Apr 06, 2009 | 2001 Chevrolet S-10
How to adjust handbrake 2001 hyundai grandeur xg
remove back wheels with screendriver adjust handbrake remove rubber plug from disc brake rotate disc brake down and look inside the disc with light;ask other people with ML (mercedes) ,JEEP,GM
Feb 26, 2009 | 2001 Hyundai XG300
Right front wheel/disc brake? heat up
most likely a brake line causing problem. it is either the rubber hose or caliper sticking. the rubber hose will collapse and cause pressure to stay on the caliper
Nov 14, 2008 | 2001 Dodge Dakota
Brake light stays on!
Checked the fluid level in the brake reservoir yet?
Jun 24, 2008 | 2001 Honda Prelude
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
