Question about Ovens
Parts diagram for SCA2001FSS02
Have you found waht you were looking for? I am not sure if a parts diagram would show the proper position of the switch. Also, I think the spring on the door latch that touches the switch is too tight which makes the door hard to open and may be moving the switch. Awaiting your reply.
  • Anthony Saba Apr 02, 2008
    I figured out how to snap the switch back into place. It does go on an angle but ot fits perfectly. I tried the MW and it did not work so I ordered a new switch and will try that out next. Can I test the switch with a continuity tester (ohms)?
    Also, I am considering opening up the MW door and relaxing the door spring a bit but not sure if I should. What do you think?
  • 3,587 Answers
Yes..I saw that..I'd say that the original install is at fault. I suppose it's well beyond the warranty period, right?
Posted on Apr 02, 2008
I'm looking for a schematic to show how to reassemble the oven door after replacing a cracked glass panel (with a Whirlpool ordered part).
Enter your model # at Automatic Appliance Parts site and they will likely have an "exploded" diagram of the door pieces. just be slow and lay it out in order of how you dismantle it, thats what I do.
Mar 16, 2016 | Whirlpool Ovens
Kitchen Aid Oven KERC601
d u have the serivce manual for this>?
Jun 06, 2008 | Ovens
The exploded parts diagram can be found here: Look for part designation 119. It is a **resettable** thermal switch. There is a little red button on the top that you press in and feel/hear a click of the breaker being reset. The part number is 318004900. You will have to remove the oven from the wall, remove the back cover panel and locate it. If you are unsure or hesitant about doing any of this, CALL FOR SERVICE!
Aug 25, 2015 | Frigidaire Ovens
I need a wiring schematic for a Kenmore model 79040522400 wall oven . Control panel the five wire that hookup on side for broil, bake, etc
diagrams are inside the control panel, usually in an envelope to the left or right side of center. If not there, look on the top or rear panels as they may be adhered to either of those. Worst case is someone took them from the unit during service in the past and never replaced them. Last option is to look online at sears parts direct. They show the diagram, but it is not clear.
Jan 26, 2015 | Kenmore Ovens
Where could I find older model thermostat replacement for Kenmore 2784218590 Model # Thermostat Part # 326542
You're going to be hard pressed to find that exact part. What I would do is start looking into replacing it with a universal thermostat. Here's one that I've used before that usually works with very little modification:
Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
Give it a shot. What have you got to lose? It's cheaper than buying a new wall oven!
Good luck
Oct 23, 2014 | Ovens
We have a Kitchen Aid KEBC147VBL03 wall oven. When we ran the self clean oven (big mistake), the oven shut off and locked. There is no display/lights on the control panel. And, the door is stuck in lo
Does the control board or anywhere of control panel have a fuse? If not beter have it service. Expect a quotation from the serv. Tech after it found how big or expensive theparts tobe replace to make ur unit operational agian
Sep 22, 2014 | Ovens
Control board harvesting
No, the parts aren't the same. The W2BB model has this code for that same part WB27T10283, while the A2BB model has this code for that part WB27T10292. The parts Look exactly the same in the diagrams, however in my past I have discovered the hard way that connectors and things in the circuitry are often different even if they fit. They're pretty pricey too 250 bucks or so...good luck!
Sep 01, 2012 | GE JTP45 Electric Double Oven
Why does oven light keep burning out on my Whirlpool Oven?
First, be sure that you are using the correct lamps, they must be aplliance bulbs, rated for use in ovens. Secodly, some oven light fixtures are equipped with a lens, and if this is missing the lamp can be exposed to very hot conditions, such as during auto-clean cycles, If you are not sure if there should be a lens, take the nameplate info to the manufacturers website, and look up a parts diagram. The nameplate can usually be found on the frame of the drawer below the oven door. Replacement lenses are relatively inexpensive, and the parts department at any appliance showroom can help you.
Also, opening and closing the oven door roughly, can break the element, especially when hot or cooling down. I hope that this is helpful, Rob
Jan 01, 2011 | Whirlpool Ovens
Maytag oven, top door has lost the middle open position, falls freely and does not close well on its own. Model cwe5800ace. How do I access to inspect and/or repair?
Here is the body parts diagram of the Maytag CWE5800.So this will help you out in more depth.Please the link to so you can see other parts how it is linked to door too.
Click here to get to the body parts to assemble it.
Hope this will help you,
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | Maytag CWE5800A Electric Double Oven
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
