Question about Kenwood KR-X1000
LEFT SPEAKER HAVE STATIC SOUND AND NOT CLEAR
MY LEFT SPEAKER DOES NOT OUTPUT A CLEAR SOUND; I HAVE RECHECKED THE CONNECTIONS BUT IT STILL DOESN'T CLEAR UP.
THIS ONLY HAPPENS IN THE SURROUND, DPS LOGIC, HOME THX CINEMA AND DOLBY PRO LOGIC 7 DOLBY 3 STEREO
  • 871 Answers
Hey there
The magnets collect dust and cause static noise. The wire connections could be loose too. Clean the dust off the magnets and diaphrams(carefully) and check all connections to the speakers.
Check maybe a microphone is on and is close t o your speaker it also happens a lot .
also, if the speaker is very near to a powersource and monitor, this would also give the static sound, so put it away from those 2
also check the wiring because loose wiring tend to minimize the sound output of the speaker. if you see a cut there, its better to tape it up or rather replace the whole wire to successfully get rid of the static sound problem.
When the sound cracks or the effect of the surround is difficult to hear, This only means that the system
activates the Dolby digital bass redirection circuitry and outputs the bass frequencies of the speaker from
subwoofers. thus, your other speaker sometimes recieve too much frequency making it sound dull or too static.
feel free to post any questions that you have
thanks for using fixya
Posted on Apr 02, 2008
  • 4,234 Answers
Since this only occurs when digital processing is involved, it suggests that the problem lies within that module. This is not a connection problem. It is a processing problem. Expect a cost of $50-$75 for parts plus the local labor rate for repair.
Dan
  • ABRsvcs Apr 02, 2008
    I hate to disagree with another poster here, but I have been repairing audio for a long time. I have also been an Onkyo authorized service center. The problem lies within the digital processing section. What Early1234 has stated is true, but would effect all sounds not only when the processing is engaged.
    The voice coil is isolated from dust collection by the spider (orange part close to the magnet) and the dust cap (the round hump in the center of the speaker. It is unlikely that dust would effect a speaker.
  • senyah_el
    senyah_el Oct 21, 2012
    How does on fix this issue I have the same problem
  • 4,102 Answers
Hi what are you listening to like cds or tape or radio also are you using copy cds
I have Philips Flat Tv model # 42pf7320a/37 ..I have a clear picture but no audio, just white noise and static.
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 23, 2015 | Philips 42PF9630A 42 in. Plasma Television
Right speaker channel doesn't sound clear anymore
If it sounds like static, and the bass really effects the sound it is most likely going to blow.
I would suggest taking it easy on the volume or switching your volume settings so its more on the left speaker than that right, but still with sound coming out the right one. Just so you don't blow it as fast.
Nov 17, 2014 | Audio Players & Recorders
Sherwood RX-4109 receiver has no sound. Right speaker had no sound, and I tried to see if switching speaker connections in back receiver would help, but now neither speaker works, and there is not...
Maybe a shorted right speaker took out the other channel. Does it turn on now?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
You can test the speaker for open or short by touching a small battery to the speaker wires. It should make static or click sounds. If not, it's dead. If it sparks and akes no sound it's shorted and dangerous to any amp.
Mar 24, 2011 | Sherwood RX-4109
The left rear poineer speaker will not work, all other speakers will work and all are hooked up properly but no sound will come from the left rear. How do i fix this? any secrets
you may have a bad speaker. try connecting a different speaker output to the speaker and see what happens. if it still doesn't work, you have a bad speaker. if it does work, that output is probably bad and the output ic will probably need to be replaced. there is also a possibility there may be bad solder connections inside of the deck.
Jan 28, 2011 | Pioneer DEH-P2900MP CD Receiver...
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Left speaker has developed a hum. Checked connections and all seems well. Sounds raspy like the speaker has blown.
This is likely due to a problem with the amplifier. You may have turned up the amp to the point of overdriving the speaker. The distortion at these high levels cause clipping and turn what was once crisp, clear sound into a muddied, garbled mess.
If the speaker is left connected to that source long enough, damage to the speaker and the amp may occur.
Without changing positions of the speakers: You can disconnect the affect Front or Rear L & R speakers and swap them (connect the L speaker to the R output of the amp and vice-versa). If the buzzing / hum "moves" to the other speaker, then the amplifier has the problem. If the buzzing / hum stays with the same speaker, the speaker has issues and is likely "blown".
Either way, it is probably not going to be a "cheap fix"
Jun 24, 2010 | Boston Acoustics VRS Micro Speaker
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
2004 Harley UC Radio - no sound on Left side
how about the antenna this could be the main problem im not a motorcycle expert but radios i do know and if your getting static the antenna which is called the aireal << spell check is not picking up enough signal
also head phones could be also a bad set
May 26, 2008 | Harley Davidson 426290 AM/FM Radio
Kenwood KR-X1000 Logo
303 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Eddie Dalton
Eddie Dalton
Level 1 Expert
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
