Question about Hitachi CP-X980 Multimedia Projector
Screen Width Adjustment
Hi.
we have bought a new Hitachi Multi Media Projector.
The Problem is that the screen width is unequal i.e. it is not a perfect square,rather the screen display is larger at base and go smaller as we go up.
we have tried keystone feature.
  • 563 Answers
Hi there
Try lifting up the Projector or lowering it. If it shows ok then , you'll know what to do . See it all depends on the height of your screen and the height at wich you are Projecting at.
Also check if this Projector has three places at the bottom for screws to go in , which would make it's lens even worse because these type of Projectors are actually made to be mounted upside down.
If you flip the Projector upside down whilst on , you'll see what I mean.The angling is made for it to be upside down.
Hope this is of help
Posted on Apr 02, 2008
SOURCE:
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
Mar 20, 2011 | Televison & Video
I m using acer moniter,i got the probs with its screen display..width of the screen is expand until max n now pic doesnt look good because width is wider then its height...can u pls assit me how to decrese...
You need to set the PC VIDEO resolution to the native resolution of the monitor to get correct aspect ratio (not adjustable at the monitor, the adjustment is doen at the PC VIDEO card setting), you need to find that out from your monitor owner manual.
Mar 22, 2010 | Computers & Internet
How do I make the picture fill the width of the screen. I see a 16/9 and 4/3 buttons but they only make the picture taller, I need to make it wider. I have a Vidikron Kronos One projector.
Could you please give me more detail as to what you mean by make it wider. Is the picture currently using the width of the projected image? Have you used this projector before? Once I have more information I can assist you further.
Thank you,
Lee
Feb 08, 2010 | Televison & Video
Help!
I should be able to help you out. I will need the measurements for the screen. Measure the hiegth and width.
Mar 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Crack in screen cover
measure the heigth and width of your screen I have a source that has numerous used screens for projection sets both widescreen and regular. I should be able to help you out new screens are expensive and almost impossible to find used.
Mar 25, 2008 | Hitachi 43UWX10B 43" Rear Projection...
HOrizontal width problem
With older sets i found dust as the main culprit in simmular situations.check for any  adjustment pot on the circiut controlling the screen width[normaly 3 pots close together open back of set to reveal electronic's]. be very carefull not being electrified as the set must be in operation while doing the adjustment.even turning the pot forward and back and then to the original position sometimes solve the problem.
Oct 17, 2007 | Televison & Video
Hitachi CP-X980 Multimedia Projector Logo
160 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
