Question about Brother Office Equipment & Supplies
How do I remove and change the toner cartridge on my brother laser printer? I have managed to lover the back opiece of plastic but am now flumoxed!
  • mikkicanion Nov 15, 2008
    I cannot figure out how to change the toner cartridge on my Brother HL-2170W. Can't get the old one out, can't fina my manual
    HELP
  • Anonymous May 17, 2009
You need to take out the toner cartridge with the black tray underneath. it will all come out.
Posted on May 03, 2009
How to change laser printhead
Laser printers do not use a printhead.
When the toner runs out you need to get a new toner cartridge which includes the print drum.
You lift up the cover to reveal the toner cartridge, grab the cartridge and pull it out towards the front of the printer.
Reverse this procedure to insert the new toner cartridge.
Apr 09, 2012 | Brother MFC-8870dw Wireless Multifunction...
How do I access and change out the toner cartridge? (brother HL-2140 printer)
1 Turn your Brother HL-2140 laser printer on.
2 Open the front cover by pulling the top latch toward you.
3 Pull the printer drum unit toward you. Put it on the clean, blank sheet of paper.
4 Push the green lever on the drum assembly down.
5 Remove the empty toner cartridge from the drum unit.
6 Shake your replacement toner cartridge gently to evenly distribute the toner inside.
7 Put the new toner into the drum unit and slide the unit back into your Brother HL-2140 printer. Close the top cover.
See also Brother user manual for this model at: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Feb 25, 2011 | Office Equipment & Supplies
How to change toner cartridge TN330
Hello
Once you have the correct Brother Toner for your printer model, power your printer OFF and open the cartridge box.
Next, you need to open the top cover of the printer. You should do this carefully to prevent damage to the interior or exterior of the printer.
Once the printer top cover is removed, you want to extract the empty Brother Toner cartridge from the printer by pulling upward and away from the machine. You should be able to do this without a great amount of force.
After you've taken the Brother Toner cartridge from the printer, you want to prepare the new cartridge for insertion. To do this, you need to remove it from the plastic bag it is contained in. Next, you need to remove the rip strip from the cartridge. The rip strip is attached to a plastic film strip. Removing the rip strip is important because if you don't your printer will only produce blank sheets. Take care when ripping the strip off, as you may get Brother Toner on your clothes which can stain. If you end up spilling toner on yourself you can wash it off with cold water.
Next, you want to place the new cartridge in the printer the same way the old Brother Toner cartridge came out. There will most likely be arrows on the package to guide you in the placement that will help you make sure you're putting it in correctly. Much like removing the used Brother Toner cartridge, it should slide in with minimal force. If it doesn't slide in easily you should make sure that the Brother Toner cartridge is the correct cartridge for your model printer and then make sure that it is aligned correctly.
Once you have the cartridge in the printer properly, put the printer lid back on.
Now you are going to print a few test pages to make sure that everything is working the way it should. If the printouts look good: You are done. Package the old toner cartridge in the box the new toner came in and recycle it. If the printouts look bad: Sometimes cartridges can be defective. If there were problems with your test pages, you may need to try the process again with another toner cartridge.
Jan 17, 2011 | Brother Office Equipment & Supplies
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
My Brother HL 4040 says "toner life end" for the black toner. I was just replaced a few days ago, printed OK now its empty?
Gently pull the toner cartridge out. don't want to spill toner,,, inspect to see if all plastic has been removed. warning toner is super fine soot do not repeat do not vacuum it up ,,, messes up vacuum and puts dust in air,,stains clothing
Look at contacts on toner cartridge and scrub with old tooth brush,,, look at contacts of printer same same.
Nov 27, 2010 | Brother HL4040CN Laser Printer
How do I change the toner?
Please the see the Brother support instructions here and here to guide you through the toner cartridge change.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 23, 2009 | Brother HL-2170W Laser Printer
Brother MFC6800-says change drum soon - is that hard to do?
yes anyone can do this, the drum is the unit the toner fits into, remove as though you were removing the toner cartridge, that the toner all the way out of the drum unit and install the old toner in the new drum and slide back into printer, again the drum unit is just the casing that your toner cartridge slips in and out of
Apr 02, 2009 | Brother MFC-7220 All-In-One Laser Printer
Status red and amber Toner light
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Aug 09, 2008 | Brother HL-5240 Laser Printer
Brother HL-2070N
stars-5-0._v47081849_.gif Masking Tape Gives TN-350 Toner a Second Life, August 25, 2008 By C. MACPHAIL "cmacphail3"drop-down-icon-small-empty-arrow._v13355991_.gif
After the "Toner Life End" message appears, it refuses to printeven one more copy. Offensive...until you show it who's in charge.
Remove the cartridge and find 2 clear plastic port holes, one oneach side. The printer shines a light through these to decide when toshut you off. But it's too sudden and too early.
Cover one or both windows with a small piece of masking tape. I get about 3400 copies per cartridge instead of 2400.
(Reportthis)
Aug 17, 2007 | Brother HL-2040 Laser Printer
931 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
