I have a philips 32PF9976 LCD TV and want to connect a Subwoofer to the Sub Out. Does it need to be a powered Sub. Any info you can provide would be well received...thanks.
    Problem Solver:
  • 12 Answers
Pretty sure most if not all Sub's are powered.
Posted on Apr 02, 2008
SOURCE:
I brourt a jamo sub 200 and five a102speakers but
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Aug 31, 2014 | Audio Players & Recorders
32pf9976 set time
Its in the main customer menu and changed with the original remote.
Nov 04, 2012 | Philips 32PF9976 32 in. HD-Ready LCD...
I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips Audio Players & Recorders
I have a tv Philips Model: 32PF9976/12 but image doesn't work only sound
I have the same problem...Only sound nothing else... the screen does not even light up
Feb 25, 2011 | Philips 32PF9976 32 in. HD-Ready LCD...
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Dec 31, 2010 | LG 47LG50 47 in. LCD HDTV
Connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
electech
Nov 23, 2008 | Yamaha HTR-5850 Receiver
Can I use my s750 speakers connect through A receiver?
I would actually suggest connecting the speakers up like that because the preamp that is used in the S750 is not very good even though the actual amps are good. I would also recommend using a different sub since it is very difficult to bypass the amp for the sub. Using a different amp could also provide more volume you would just have to make sure that you don't blow the speakers. I have a set of S750's but I have not been able to find anything to tell me the exact power handling that the speakers are capable of but I believe that they can handle a lot more than what the internal amplifier is putting out.
Oct 30, 2007 | Creative Labs Gigaworks S750 Computer...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Ekse
