Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
HOOVER STEAMVAC F7425-900
THE BRUSHS ARE NOT TURING. TOOK BRUSHES OUT. WHERE STEM FROM BRUSH ATTACHMEN FITS INTO, WAS NOT TURNING. I HAVE HAD THIS UNIT REPLACED THREE TIMES, UNDER EXTENDED WARRENTY. HOW DO I TAKE COVER OFF ON BOTTOM UNIT TO GET TO GEAR MOTOR. MAYBE IAM NOT GOING TO RIGHT PLACE. WILL BE LOOKING FORWARD TO YOUR REPLY/ THANKX OLDWOODSMAN
  • 1 more comment
  • helplessinVT Jul 02, 2008
    Brushes fell off and I put them back on, the turbine is not turning at all, how do I clean it or check the motor
    Helpless in Vermont
  • OLDWOODSMAN Jul 30, 2008
    Thankyou with help for the scrubber. I do still have a problem. I thought I had put unit together the way is hould have been, but I think I forgot a part or installed it wrong. There are two ports on the underside of the unit. One is lcoated next to the air filter screen. The other is abt. 4" to the left of the other port hole. When I turn unit on large amts of air is coming thru both ports & the brushes are not turning. Did I forget a part or just installed something wrong. Thankyou oldoodsman
  • OLDWOODSMAN Oct 04, 2008
    I have asked before on my problem with the Hoover Steamvac F7425-900. However, I still have not yet fixed my problem. I replaced the drive unit that rotates & turnes brushes. Underneath on bottom side of unit is a ivory colored plate. Now just in front of this plate, towards clear plastic where brushes go, are 2 holes where right now a large amt. of air is exiting. Iam sure this is not right. Have I misplaced a part or installed something wrong. The hoses on top of unit are attached correct. Please help me if you can. Will be awaiting your reply Mike
Thanks for the information reddevil6. I just purchased this SteamVac last month and I used it three times. I cleaned it after each use. I read all the literature on what not to do and what to do. So the unit said that it has enough grease for life of product??? When I took the turbine apart on both sides, there was no grease. Lubed the it up and runs like a champ. Thanks
Posted on Oct 17, 2008
    President:
  • 1,673 Answers
There some screws off from the bottom, remove the top cover, the turbine has 2 screws on the front of it and there 2 long screws you take off from the bottom, remove the tubing and it should come loose. Some times you can take it apart and clean the inside parts and it will work ok, if that doesn't do it then you have to replace it.
Posted on Apr 07, 2008
  • Lauren Junge
    Lauren Junge Aug 05, 2008
    The 2 ports on each side of the turbine are for the tubing to hook to. There should have been a tube on each side of the turbine.
Brushes not turning and water not being picked up
Frozen up Turbine is a 95% probable problem. Bearings rust! Take brush block out ad insert a screw driver (size of brush bock stem)where brush block stem goes up and in. Insert and try turn screw driver. Should turn fairy easy, some resistance because gear driven! Common problem! Can buy turbine on Ebay but be careful you order the right one for your model. They look the same but 5 brush and 6 brush turbines are different. Think I paid about $36 for one and did it myself but not the easiest. Good luck!
Apr 21, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Spin brushes not turning
Most all Hoover SteamVacs rely on a turbine to create suction and spin the brushes. The brush block (removable, just clips in) will have one of the 5 or 6 brushes with a stem inserted up and in the turbine. Hoover did a poor job sealing the hole that stem goes through and water and cleaner seep up to the lower bearing on the turbine and the bearing siezes. The turbine has a gear assembly inside! It is not easy to replace the turbine, especially the first time because what needs to be removed can be a head scratcher. However goes easier the second time. The turbine can be taken apart once out and I have used light grease to free up the bearing and gears but it's only a temporary fix. Different models have different part # turbines so pay attention when ordering the part. Need a work bench environment to do this. On occasion the brush block itself can get stuck because the brushes gear mesh together and the stemed brush drives them all. They can and do bind up with junk and do wear down and bind. If you can't turn all 5 or 6 brushes by spinning with your fingers on the stem, the block itself could need replacing. The block and brushes do come apart for cleaning but be careful because they are plastic clips on both halves of cover/retainer and can break.
Sep 16, 2013 | Hoover SteamVac F5914-900 SpinScrub...
Brushes aren't turning. switch is on
Remember that the brushes turn best when the handle is tipped back. If this does not work, remove the brush assembly and insert a flat screwdriver into the square hole that the pin on the brush usually fits into. Try to turn the fitting. If it won't turn, the air driven turbine has seized up and will require replacement.
Jul 26, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin
First, please be sure to unplug your Steam Vac and remove both the clean water and the dirty water tank.
There should be a square stem that sticks up in the center of your brush assembly. If this stem is broken you will need to replace the complete brush assembly. If the stem is good; turn your cleaner on it's side and check in the area where the brush assembly goes (with the brush assembly removed). In the center of this area there is a square hole where the stem from the brush assembly goes. The square hole is in the bottom of the turbnie that spins your brushes. Using a large flat blade screw driver (not so large that you'll damage the hole), stick it in to the square hole and try to spin it. It should spin freely, if it is very hard to spin or won't spin at all, your turbine is bad and will need to be replaced.
Hoover part number for brush assembly:48437022
Hoover part number for turbine: 43191008
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes donot turn when asked to shampoo
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Feb 09, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes do not turn
F7425 Parts Link
Dec 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac Spinscrub F7222-900 brushes do not engage. Brushes will spin when unit is laid down and the brushes are pushed upward, forcing the male brush linkage into the female receptacle , but when...
If the stem is not making proper contact to the recepticle, then this is one issue. replace the brush block. The other issue could be turbine related, requiring a service shop repair. also check the red filter under the machine for lint.
Oct 24, 2009 | Vacuums
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover Steamvac- the brushes are not rotating neither L or H
my hoover steamvac the brushes are not turning what makes the blue triangle that the brush attachement fits to move?
Feb 21, 2009 | Hoover F5900-900 Upright Steam Vacuum
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
203 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
