Question about JVC TH-M303 System
No sound. I have no sound through my system, the woofer light comes on and everything else seems to be working. After searching through your solutions page I plugged my headphones in and got sound back. Any advice or is it screwed?
  • Marbron Apr 02, 2008
    Thanks for prompt response Dan. No cant get any sound other than through the headphones. Weird.
  • 4,234 Answers
Did you get sound through the entire system after plugging in the headphones? If so, the headphone jack is acting as a switch and probably has some dirt/debris that should be cleaned. The easiest way to do this is to get some electronic switch cleaner (one that contains a lubricant as well) and spray into the headphone jack. Insert and remove the headphoe plug a number of times and the problem should be resolved.
Update this if the problem returns and we'll look further.
Dan
Posted on Apr 02, 2008
  • ABRsvcs Apr 02, 2008
    Ok. That helps a bit. The "amp" for the headphone can be different that the amp for the remainder of the system depending on the design. In your particular case, the headphone amp is most likely a 4558 chip. That means that the output amp is in protect mode. There is a problem in the final stage that is preventing the system from turning on the speakers. This is to prevent damage to either the speakers or the amp itself. I believe that this model uses discrete transistors, so that the parts will run $15-$25. Add to that the local labor rate for the compete repair cost.
    Dan
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
My woofer is not working as if there is a short somewere it comes on then when moved it goes back off
sounds like the contact points on your 9 pin DIN connector are corroded. If carefully cleaning each pin sounds like too much work, a search on ebay for a male 9 pin mini-din might bring you joy. But THAT solution requires some soldering.
Jul 13, 2011 | Dell HK395 Computer Speakers
I have creative inspire T6100 5.1. my working window is widow 7 in my pc. In sound test all the speaker are working but when i play songs then the center woofer & 2 rear woofer not working. they dont...
You may have to enable the additional speakers by entering the Creative software, which should have come with your sound card. On my system I left click on the Creative volume panel and the choose console launcher. After entering the Console Launcher you can change the speaker setup.
Feb 27, 2011 | Creative Labs Sound Blaster Live! 5.1...
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
"Check Battery Light" coming on after a repair job
Sound like alternator is not charging enough,
I would check charging system.
May 04, 2010 | 2006 Toyota Sienna
No sound
if the display is working your pre-amp is ok
check the sub-woofer
amplifier is in the sub-woofer, check fuse inside first
after that mail again, thanks
Feb 15, 2010 | Bose 3 2 1 GSX System
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Repair of Z560 amplifier
try fixing its amps by simple reheating it. if still doesnt work try replacing its parts... it is certain that it has a prob on the amps.
Oct 14, 2007 | Logitech Z-560 Computer Speakers
JVC TH-M303 System Logo
174 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
