Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 Input 480i
When I turn the set on the screen is black. This message appears in top left corner of screen for 2 seconds and disappears:
Input 1
480i
Need help resolving, please.
Karen
Input 1 means it is displaying the signal from Input 1 on the back of the TV. Make sure your vcr/dvd/cable box is properly connected and working. If nothing is connected to Input 1 then press Device on remote and select the proper Input to display.
My cable is connected directly to my TV on ANT1. I, therefore, select Antenna 1 from Device list and my picture is displayed fine.
Hope this helps.
Posted on Apr 30, 2008
  • 31 Answers
It is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Posted on Apr 28, 2008
Why does my Mitsubishi WD-65737 TV go black for 4 or 5 seconds then picture comes on again with the top left corner says "Cable Box".
Replace service cords, as they might be getting worn and loose. It does sound like that to me. Bad coaxial cables
Apr 10, 2015 | Mitsubishi WD-65737 65"" rear projection...
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-62525 sound will come on but no picture.
Your tv would turn on if you replace the only two 3300µf@16v capacitors on the power board . You wil notice they are bad by the way they bulge up at the top and may be leaking electrolyte a little from the tops . But the rolling lines would still remain but much less noticable.Then other symptoms will eventually appear. Truth is many many many many other capacitors need to be replaced inside the electrical chassis. Your TV would need to go to a repair shop that is expierienced in that repair because it is so extensive.
Oct 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a wd-52525 mitsubishi and it is supossed to be 720p but when I turn it on it says its 480i. What part of the tv makes it 720p or 1080p? Please help.......Thanks Paul
You will have to use component inputs for above 480i, and use the FORMAT key on your remote control unit (lower panel in center) to change to whatever you want for resolution. Be sure you have your signal input set to one of the Component inputs via Setup or Net Command (or use Devices on the remote)
Jul 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Power on tv and I get black screen with sound.
You have lost the input signal...you will have to go to Setup/Net Command and set your input to the one with signal (either a TV input or a Component input). If it is reset...the input likely switched to a non-usable input
Jul 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
62' DLP WD-62525
Since the set turns on and displays this message we can asume the set is working, so for the next step simply change inputs and see if something comes up, either there is nothing hooked to input 1 or the device hooked to input 1 is off or has failed
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
227 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
