Question about Epson Stylus C44UX InkJet Printer
Ink carriage When you press the ink carriage button for a few seconds to replace the ink cartridge the carriage does not clear the rhs printer body so only the black ink cartridge is accessible. How do I get the carriage to move further left?
  • Anonymous Jul 07, 2008
    Mine does this all the time , the only way is to keep pulling power cable out, till things are in right place. Cheers
    Novelist:
  • 110 Answers
This is a tricky little printer. Here is your fix.
When you hold down the ink button for 3 seconds, the printer will perform a cleaning cycle.
But if you continue to hold the button for 10 to 15 seconds, it will then come ove to the opening where you can access the cartridges.
Posted on Aug 22, 2008
24:10 code error
The system error 24:10 is a critical error in which the printer cannot be used until has been corrected.
Turn the printer on in Diagnostic Mode. Turn On the printer holding down Power + Cancel + DOWN buttons until you hear one beep before releasing ALL three keys.
Note:This could take few attempts to find correct timing on holding the buttons down, remember to hold the down key and cancel key and then hold the power button key so all 3 buttons are pressed until bleep at 5 seconds then release. Each attempt you have to wait for boot up to see if it powers up to the below diagnostics menu.
Scroll down to "Service Special Utilities" and select OK
Scroll down to "Bag Broken Recovery" and press OK to start the process.
Note: This procedure will only help if problem is just with a ink carriage just been fitted in the last 6 hours.
The front panel will display a series of questions which you answer Yes or No depending on the status of the printer. Use the Up and Down arrow keys to select Yes/No and the OK key to confirm the selection in each case.
Remove the Ink Cartridges and check for any ink leaking from the cartridge. In extreme cases ink
can contaminate the ISS PCA area which will then require instalIing a new ISS PCA.
If the message 'Please replace one of the defective cartridges (*). The asterisk represents a
number which will identify the failed ink cartridge.
Number displayed Ink Cartridge Color Failed
0 Magenta
1 Light Magenta
2 PhotoBlack
3 Matt Black
4 Yellow
5 Light Cyan
6 Light Gray
7 Cyan
  • Question 1:'Are the Tubes from the Air Pressure System (APS) to Ink Supply System (ISS) Clean?' YESIf the tubes are clean of ink select the Yesoption. However if the tubes have sections of tubing that have ink in them, select the Nooption and replace the Tube assembly.
  • Question 2: 'Do tubes from the ISS to Carriage contain visible air?' NOIf the tubes between the ISS and the Carriage Assembly do not have air bubbles, or clear sections of ink tubes where air is present mixed with ink, select the No option. However if you can see air in them, select the Yes option and replace the SRK assembly.
  • Question 3: 'Do you want to remove the broken bag condition?' YES At this question select the Yes option to clear the broken bag error.
To finish the procedure select any key on the Front Panel and the printer will shut down.
Insert the new Ink Cartridges into the printer and turn On the printer.
Note: If the Tube assembly needs to be replaced, the Broken Bag Recovery procedure will still need to be performed after they have been replaced.
If you need any more help or service please contact 1st Call 4 Service Ltd.
Feb 15, 2014 | HP Designjet Z6100 InkJet Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to replace canon print head printer ip90
After you open the cover and the carriage comes to the center for new ink, you press the resume button for a few seconds and the carriage will go to the printhead changing position. You don't want to ever force the printhead to move. Hope you didn't break something already. Sorry for the stupid help.
Oct 04, 2009 | Canon PIXMA iP90 Mobile Printer
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Priner carriage does not locate to enable change of cartridge
Hi
Try to turn it off and turn iit back on then press and release ink button that has the tear drop symbol if theres any, that should position cartridge holder where you can replace it.
Pls update me. thanks
May 13, 2009 | Office Equipment & Supplies
Can not get the ink tray to stay so i can change the ink tx 100
Press the Ink Button on the printer and lift the lid. The ink carriage should move to the pointer to indicate the first cartridge that has gone. Press the button again, and it should move again to the next cartridge. When it has gone through all the empty units, it will move to a clear part of the printer and stay there until you replace the cartridge(s). Press the button again and it should move back and charge the heads with ink.
Mar 05, 2009 | Epson Office Equipment & Supplies
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx 205, can't change the cartridge
With the power on and the lid up, click on the red stop (left panel). You will notice the cartridges move to the left and then they come back and stop halfway. Afterwards you should be able to slide the cartridges manually with your hand to the larger area on the right where you could do the cartridge change. Once you've moved it to that area just the lift the cover where the arrow is.
Jan 12, 2009 | Office Equipment & Supplies
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus C44UX InkJet Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
