HP nc8000 LAPTOP DISASSEMBLY ETC....
HP nc8000 LAPTOP... DC POWER SOCKET NEEDS RESOLDERING/
BRIDGING TO MAIN PCB... HOW DO I DISASSEMBLE , REMOVE INTERNAL LEADS ETC .....
WITH THANKS AMT
    Sergeant:
  • 318 Answers
I would try a new power adaptor cord 1st, they go bad alot and I have been on calls to soder the DC power socket many times, when it was simply a power cord problem.
If a new cord does not work the assembly manual can be downloaded from HP at this address:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00803690/c00803690.pdf
Posted on Apr 02, 2008
SOURCE:
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
My hp laptop don't turn on even the charger is
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 02, 2013 | Computers & Internet
Dgx 230 dc in connector bad
This type of keyboard is well know for the power socket breaking away from the main PCB. You will need to unscrew lots of screws to reveal the circuit board with the power socket on. If you look closely at the solder side you will probably see that the track that the socket is soldered to has broken. Simply link the solder joint to the circuit further along the track by bridging between socket and next point along the track. You may need to replace the socket if it has become damaged. If you can use a soldering iron it is fairly easy but if in doubt contact a repairer.
If you need a socket Google :
Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
Jan 25, 2013 | Yamaha Keyboard w/ 76 Graded Action Piano...
Wont power up no lights
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 05, 2012 | Sony Vaio VPCEA36FM
How to remove the bottom of a laptop to tighten the power supply outlet
You will probably have to strip it right down to get the motherboard out.
The socket might need resoldering. if you are not technically minded you would be better off taking it to a repair shop. You can do more damage than good if you are not careful. Youtube have a lot of videos about disassembling laptops / pc's if you want to do it yourself.
Feb 12, 2012 | HP Computers & Internet
Which components on hp nc6400 motherboard can cause input power failure
Main component to cause such an issue in the DC socket where you plug the power adapter. This is one of the weakest points in the laptop & usually the first suspect when it comes to input power failure. The socket might either be loose (in which case it will need to be re-soldered), or broken (in which case it will need to be replaced). In either case, you need to disassemble the laptop, pull the motherboard out, & inspect & fix the problem.
Aug 29, 2010 | HP Compaq nc6400 Notebook
When i plug it in i have to jiggle it a bit then it eventually works but when i move my laptop it will not charge
This sounds like either the power plug/cable is broken of which a new plug will need to be fitted or the power socket inside the laptop is broken or needs resoldering to the PCB (known as a dry joint)
Jul 29, 2010 | Computers & Internet
Broken dc power socket
In the case of your laptop, the dc jack is connected to the motherboard by a cable and socket...so there is no soldering that needs to be done. You just have to disassemble the laptop and replace the cable. Below is the link to Ebay where they have one listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=Toshiba+Satellite+A100+dc+plug&_sacat=See-All-Categories
Below is the link to the service manual for the procedure.
http://tim.id.au/laptops/toshiba/satellite%20a100%20a105%20tecra%20a7.pdf
Jun 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Hi i had arrived to the dc socket how do i remove it???
below is the service manual for your laptop. Disassemble the system down to the motherboard. The power socket is described on page 83.
http://h10032.www1.hp.com/ctg/Manual/c01572022.pdf
Nov 14, 2009 | HP Compaq Presario CQ50-103NR Notebook PC
Open Questions:
SBCglobal MAil TecHNicAL SuPPoRt /*-+{1-855*536*5666}#[email protected] SUPPORT NUMBER This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 16, 2019 | Best Computers & Internet
Malwarebytes SUpPoRt Helpline 1[+-855#536.5666] nUMber O+$ Malwarebytes Antivirus Tech Support Number @+1855 536 5666 tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 16, 2019 | Carrier Computers & Internet
SBCglobal MAil NuMbER */-{1-855*536*5666}#[email protected] NEVADA This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Computers & Internet Logo
1,449 people viewed this question
Ekse
Alun Cox
