Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Usb 2.0 wlan
Have got broadband through sky, netgear wireless router. on my laptop they supplied me with a usb 2.0 but cant get internet on laptop, can only use it if i am plugged in!! any suggestions?
  • greyoldgit Apr 06, 2008
    i cant get internet set up on my netgear usb 2.0 adapter
I had exactly the same problem and had to go to the PC card Netgear WG511
for some reason the USB one conflicts with some things on certain laptops
I now am able to get the internet wirless on my laptop
good luck it nearly drove my crazy trying to get it to work!
hedgehog6865
Posted on Apr 02, 2008
SOURCE:
How to install a Wireless-N 3G MIMO Broadband Router
What are you trying to connect with ? A laptop? What kind? What OS are you using? If it's connected correctly and you can access the internet with a Ethernet Cable attached to the Netgear and the computer, it may be a computer wireless issue.
Jan 18, 2013 | NetGear MBRN3000 3G /4G Mobile Broadband...
The Internet LED is red when there is no Internet connection
Unplug router for a minute or so and re connect also check if the computer is even recognizing the router in control panel under network conections
Jul 09, 2012 | NETGEAR CONSUMER Netgear Dgn2200m Wireless...
One PC will not connect to Router and therefore Internet.
Sounds to me like the problem is related to the PC hardware. Please check the following in your PC:
- Network card is properly working
- Network cable connecting to the PC is properly working
Sep 21, 2009 | Belkin (F5D5231-4) Router
Netgear Wireless - G USB 2.0 Adapter
Hello, Joe.
Assuming Sky doesn't prevent access to non-sky internet services (if they did something crazy like that, it is most likely a Sky specific firmware that was put on the router, which would mean you need to put the Netgear firmware back on), I would say you have something set up wrong.
Can you get to the internet through a wired connection? If so, wireless is probably configured wrong. If you can log into the router, that would give you an easy way to find out how thw wireless is set up. goto your web browser (on a wired connection to the router) and type "192.168.1.1" or "192.168.0.1" When prompted, type in your username and password (probably, "admin" and "sky" or "admin" and "admin").
If you can't log into the router then you'll have to try and figure out the connection through trial and error. When you were with Sky and the tech installed your router, did he/she give you an encryption key to use when you connected? If so, I would try "shared WEP" first (providing the WEP key given to you). If that doesn't work, try WPA-PSK.
Hope this helps,
Bill
Sep 03, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Sky netgear router
add your previus setting in your netgear router
fist you have contect with your pc and config and fist resert the all current seting
Mar 31, 2009 | NetGear RangeMax Dual-Band Wireless-N...
I have bought a laptop from someone and it has a edimax EW-7305Pg wireless LAN Cardbus. I am having problems connecting it to a netgear wireless router supplied by sky. I have sky broadband. I uninstalled...
is the mac address registered through your wireless router, your router maybe running wireless mac filter, if not try registering your wireless mac address on your router then try reconnecting your computer to your router.
Feb 01, 2009 | Computers & Internet
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Blutoohth
Hiya, I have sky broadband too, with a Netgear wireless Router, your second pc needs a wireless card or usb wireless dongle to located wireless networks, once its installed you need the security key for the network, what equipment have you got?
Mar 25, 2008 | Computers & Internet
Open Questions:
ZONEALARM Antivirus Helpline nUMber I{8OO`8O31''O69} o ZONEALARM Antivirus SUpPoRt nUMber LTqNyM ZONEALARM Antivirus SUpPoRt nUMber {18OO`8O3~IO69} OO%^& ZONEALARM Antivirus CuStOmEr Care Number +l8OO8O3`IO69 to resolve all ZONEALARM Antivirus products. ZONEALARM Antivirus is an American multinational company which was founded by Michael ZONEALARM Antivirus using its company headquarters in Round Rock, United States of America.Contact ZONEALARM Antivirus for Setup & Installation ZONEALARM Antivirus Setup Support & Installation ZONEALARM Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi`Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for ZONEALARM Antivirus Connect, ZONEALARM Antivirus Helpline Phone Number you'll be searchinAg out ZONEALARM Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to ZONEALARM Antivirus Connect. Get ZONEALARM Antivirus Setup Instant Support ZONEALARM Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified to help you even if you aren't Customer`savvy. Let us undergo the method of ZONEALARM Antivirus Connect setup for Windows and for Mac. So, right here we go vikki
Oct 15, 2019 | Carrier Computers & Internet
Malwarebytes SeRvIcE nUMber #@{1;855;536;5666} o Malwarebytes Antivirus CUsToMeR SUpPoRt pHoNe nUMber S'J_FwZ Malwarebytes Antivirus CUsToMeR SUpPoRt pHoNe nUMber #@{1;855;536;5666} Malwarebytes Antivirus CuStOmEr Care Number +l855536`5666 to resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi`Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searchinAg out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified to help you even if you aren't Customer`savvy. Let us undergo the method of Malwarebytes Antivirus Connect setup for Windows and for Mac. So, right here we go vikki
See all NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, Questions
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
97 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
