Yamaha RX-500 (old n b0ld)
Can anyone help, my trusted stereo amp has stopped working!
I have power available but with no output from any selected input option? Is there a simple repair or a known defect for this??
  • 4,234 Answers
The system is most likely in "protect" mode. This means that a problem was detected and the output section has been disabled to prevent further damage. The most common failure is of the output transistors. Figure about $15-$30 in parts plus the local labor rate for a repair.
Dan
Posted on Apr 02, 2008
How do I connect my Yamaha RX-V733 to a CD Player?
I don't see a RX-V733 on Yamaha's site. However, look for a stereo audio input on the receiver. Then use the appropriate audio cable or adapter for the CD player audio out.
Depending on the CD player, you should use either an RCA M/M to RCA M/M (red/white) audio cable or a 3.5 mm headphone to RCA stereo audio cable. (If you don't have a headphone to RCA stereo audio cable, you can use adapters on either side. Examples: 3.5 mm M to RCA F/F adapter to RCA audio cable as above or 3.5 mm M/M cable to 3.5 mm F to RCA M/M audio adapter, depending on which cable you want to use and where you connect the adapter.) After making this connection, turn on the CD player, select the appropriate input.
The connection for an external audio device (like a CD player) is shown on page 31 of the manual for the RX-V773. Even if this is a slightly different model, the image may help. The manual is available from Yamaha on the product page: http://au.yamaha.com/en/products/audio-visual/av-receivers-amps/rx-v773_g/?mode=model . Click on the Support tab. The direct link to the manual is http://download.yamaha.com/api/asset/file/?language=en&site=au.yamaha.com&asset_id=54075 .
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha
usa.yamaha.com > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
www.fixya.com/.../t25422640-no_sound_yamaha_rx_530_stereo_fm
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
Jan 12, 2016 | Yamaha RX-V540 Receiver
Can I use an Ipod Dock with a Yamaha RX V490 receiver?
No, but you could still access the audio directly from the iPod...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to an amp or receiver. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
http://www.retrevo.com/support/Yamaha-RX-V490-Receivers-manual/id/319ci975/t/2/
Dec 01, 2010 | Yamaha RX-V490 Receiver
I have a Sony Bravia KDL-46X3100 tv set which I want to connect to my Yamaha RX-V730 amplifier so that we can listen to tv programmes through the sound system. How do I connect them using RCA cables as I...
all you need is one set of the red and white rca cables.your tv should have an audio output with a red and white hole.plug in red and white wires to those holes at the back or side of your tv.plug the other end to your auxilary red and white holes at the back of the stereo....if your stereo doesnt have aux holes then you can plug into L.d.,VIDEO outputs at back of stereo.you then turn your select button,nob on your stereo to either the aux,ld or video.hope this helps
Oct 15, 2010 | Yamaha AX-596 Amplifier
I have a Yamaha RX-V1400. Can no longer select ZONE 2
check the setup menu in the receiver to reset the outputs for zone use instead of 7.1 use
Oct 17, 2009 | Yamaha Audio Players & Recorders
Yamaha AV Amplifier RX V530
You might have your speakers shorted. Check the wiring at the amp and speaker terminals
Sep 09, 2009 | Yamaha RX-V530 Receiver
Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Aug 23, 2009 | Yamaha RX-V663 Receiver
Right now my reciever will only play with two speakers (L and R). How do I get the 5.1 DTS back?
Are you using single digital coaxial or optical digital or the stereo RCA cable.
You might have that buttons on the remote for surround,2channel,3channel or 5.1 channel. orGo to the DVD's setup menu and click on "Audio Setup" or on "Languages" if there is no Audio Setup option and choose "Dolby Digital 5.1." (If you have a5.1, 6.1 or 7.1 system select "Dolby Digital EX" if it is an available option.) Depending on the age of the disc, the "Audio Setup" on the DVD menu may give you several choices: "5.1 Channel Surround Sound" or "Stereo Playback." If it's an old DVD, it might even say Dolby AC-3 (the professional designation for Dolby Digital 5.1). New DVDs may offer "Dolby Digital 5.1" and "Dolby Digital 2.0," the latter being stereo. Some of the disc menus offer only "Surround Sound" or "Stereo" options.
Aug 14, 2009 | Yamaha RX-V463 Receiver
Speakers connection
There shouldnt be a problem with that at all. The subwoofer needs to be self powered. The Yamaha has a "Subwoofer Output" on the back. Just connect it there.
Apr 04, 2009 | Aiwa Audio Players & Recorders
Yamaha RX V490 Turning itself Off
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Dan
Jul 22, 2008 | Yamaha RX-V490 Receiver
208 people viewed this question
 Grubhead
Grubhead
