Question about Samsung NV3 Digital Camera
SD Card Wont Work
I have just bought a 4gb sd card for NV3. When I install the card in to the camera, a message comes up saying 'Memory Full'. The card is new and definitely empty. I have even formatted but nothing works.
Any help would be apprciated as I leave for my holidays tomorrow.
  • Tanny1 Apr 02, 2008
    Response to digiteyes:
    The packaging for the sd card state it supports a NV3 and I have previuosly used 2gb card and that has been fine.
    Response to ginko:
    Did as you advised but still the same problem. Have tried the card on my PC and it seems fine.
    Thanks for your help people.
    Tanny
    Scholar:
  • 110 Answers
From the NV3 Manual: (specifications)
External memory(Optional) : MMC/SD card (Up to 1GB Guaranteed)
So the camera may not support a 4GB card.
Try 1GB cards (or smaller).
Posted on Apr 02, 2008
  • Samsung Master
  • 19,396 Answers
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
I just got a samsung sensory pleasure nv3 i put a 4 gb memory card in it and it says memory full but the card is empty
Hi
Try formatting the SD card before using it.Also,check the storage destination of the pictures,could be they're storing on your camera and not in the memory card.Make the SD card the default storage device.
Hope it helps.
Feb 20, 2012 | Samsung NV3 Digital Camera
My camera is saying memory full with a new sd card in. why?
The Samsung NV3 can only use standard SD memory cards up to 2GB. I'm guessing that your new card is a 4GB SDHC card, which the camera is not capable of recognizing. Fortunately, 2GB SD cards are relatively inexpensive these days, and are widely available on Amazon (see this link) if your local store no longer carries them.
Oct 08, 2011 | Samsung NV3 Digital Camera
New 4GB SDHC mamory card will not work in my Samsung NV3 camera - I get a memory full message. I have formatted the card and erased internal memory with the card out of the camera and still no joy - any...
Sorry, but your older camera can only use 2GB or less standard SD cards. Fortunately, these are relatively inexpensive these days, and may be found on Amazon, if your local store no longer carries them.
Aug 15, 2011 | Samsung NV3 Digital Camera
Nv3 it says memory full even if the sd card is empty. it wont take photos
try using the camera to reformat the SD card.
Or maybe if that camera has internal memory, it is set to use the internal memory. Go to the options and set the camera to use the SD card
Mar 03, 2011 | Samsung NV3 Digital Camera
Hi, I have a Samsung NV3 camera, I have installed a new 4 GB memory card but it is showing memory full. Is there and internal memory on the camera that is full that requires deleting? many thanks
I've tried to download a manual for this camera to give you the most accurate answer possible, however after a few minutes of frustration I'm going to answer this sort of "off the top of my head so to speak" My first impression is that the 4GB memory card my be beyond your cameras capabilities but first try this. Have you checked the memory card to make sure it's not locked I'll include a diagram check the small circle for the correct orientation the arrow shows the lock position.
Diagram
Once you have made sure the card is unlocked install the memory card and then format the card. Formatting "programs and new card to work with the camera it has been installed into. Also Formatting should be done after each download of pictures to the computer hard drive. In this case formatting cleanse the old pictures off and programs the card once again to give optimum performance between the camera and memory card. If this still doesn't work then I suspect the 4GB card is to large for the camera "firmware and you will need to update your camera on the Samsung web site to a newer version of firmware. Sounds complicated but heck i did it so it's not all that technical. Also the memory card you are replacing may only need to be formatted to begin to work properly again (that's if you were having problems)
Jan 05, 2011 | Samsung NV3 Digital Camera
Memory card full but its new!!!!
Format the card in the camera to initialize it.
Oct 14, 2009 | Samsung NV3 Digital Camera
SD cards
Do the 4GB Cards say SDHC on them? They should. SDHC is simply "Secure Digital High Capacity". They're high capacity SD cards that hold more than regular cards. In this case, 4GB. The problem with these is that they need to be supported by the device. I've never put an SDHC card into a device that doesn't support them, but it looks like that's what your situation is. The highest memory capacity a non-SDHC compliant device is capable of 2GB. I recommend that you return the 4GB cards and buy 2GB cards instead.
Jun 16, 2008 | Samsung NV3 Digital Camera
SD CARDS!!!
dont go for more than 4GB it makes ur unit slow
Samsung NV3 Digital Camera Logo
262 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
