Question about Microwave Ovens
LG MS-283MCG Microwave - had a fault when we first bought it, engineer replaced an internal fuse. Stopped working again years ago in the same way, been sitting in a cupboard since then. Hardly used since purchase, don't really want to throw it away but it's obviously out of warranty. Is this something that's well known & if so, is it replacable by an amateur?
    Master:
  • 518 Answers
Microwaves usually have a small ceramic fuse inside. White with metal caps about 1 inch long. You can change it yourself but please follow these rules:
  • Always make sure the unit is unplugged when doing this.
  • Replace the fure with the same type of fuse. Don't use a glass fuse if the original is ceramic.
Other than that, I hope that fixed ya...
Geno
Posted on Apr 02, 2008
No power to the microwave, after storm.
The low voltage brownout let the oven draw too much current, and likely an internal fuse failed. Typically after removing a dozen Philips screws you can take off the cover and locate the fuse, which you can match and replace. [If it still has "power" (like the lights come on) but has stopped heating, then it could be any number of other issues (main capacitor fail, etc)] I've changed a fuse or two in my day, and years ago a failed capacitor, with success.
Jan 13, 2014 | GE Microwave Ovens
My LG over the range microwave and vent stopped working. The outlet it's plugged into is fine.
it may be an internal fuse that popped. try a lamp or something in the outlet. if that's ok, it's probably a fuse inside the microwave.
Oct 17, 2013 | LG Microwave Ovens
My LG LMVM2055 just stopped working. i have checked the fuse box and everything is fine. i unplugged the microwave and plugged it into a working outlet and it still does not work. is there an internal...
yes there is a fuse behind the control panel area. where the cord goes inside the unit there is a fuse bloack and a 20 amp fuse ...may have lucked out and just need to replace fuse...unfortunately you have to do some disassembly to get to it ...good luck to you
Jan 09, 2011 | LG LMVM2055 Convection/Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
3 year old panasonic otr microwave stopped working
Sorry but if the fuse is good your out of luck. but ck. the fuse first. best reguards DFD
Apr 12, 2009 | Panasonic Microwave Ovens
No heat
it could be the magnatron is faulty or it could also be the highvoltage fuse is faulty, i would quote the parts at $70 and the labouar at roughly $50-$60, all depends on the unit itself.i would love to help but i live in nsw australia.but i hope what i have told helps somehow.
Nov 26, 2008 | LG Microwave Ovens
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
GE 1339BW002 Microwave stopped working
Yes, there should be a ceramic (tubular) fuse under the cover on the top side where the power comes into the microwave.
Dec 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Russell hobs microwave oven
I am a recently retired appliance engineer of 20 years, microwaves are not normally things worked on yourself, i would be reluctant to help normally but yes there is an internal fuse ( a special quick blow type )just inside where the wire enters the cabinet on a small circuit board, if a replacement is needed it must be exact match bought from an electronic shop, microwaves are dangerous they store powerful electric and can still shock after removing the plug, if the replacement fuse blows, there is a fault elsewhere, and i do not recommend further self repair, work with safety
Sep 09, 2007 | Microwave Ovens
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
