Question about Gigabyte Slot 1 GA-6BXC Motherboard
Lan card at INSERT lan card in GA-6BXC hapin good instul but when insert cable in the lan hapen red and green led on 1sacand and off 1sacand but when conction in ather computer it working very god
  • Gigabyte Master
  • 19,396 Answers
Use a different PCI slot and reinstall the drivers for your LAN card. If this does not fix the problem there may be a compatibility issue between the network card and some other software (eg. irq conflict etc.), or the LAn card may be slightly faulty and have problems on some motherboard.
In this case you can try troubleshooting the problem.
If you cannot find out the problem at a glance, checking in device properties, you may be forced to reinstall Windows. In this case I suggest to just replace the part. The Ethernet (LAN) pci card is quite an inexpensive part, and you can still use this one on a different computer.
Regards
Posted on Apr 02, 2008
HOW TO INSTALL DYNEX DESKTOP 10/100 MBPS PCI NETWORK CARD
Remove the case cover from your desktop computer.
Remove a cover strip from a PCI expansion slot.
Insert the Dynex network card into this PCI slot and secure it with a screw.
Replace the cover on the desktop computer.
Boot up the computer and when Windows has booted up then insert the Dynex installation CD into the CD drive then install the LAN driver.
Connect a LAN cable from the Dynex LAN card to your modem or router etc.
Mar 11, 2012 | Computers & Internet
My motherboard cant detect hard disk ,disk driver and when i start my computer it dint show HDD LED light (red light) and it show "No Hard Disk detected, Please insert Hard Disk and Press Enter. i...
THere maybe a problem with the SATA/IDE connection.Check the connection first using another cable or try to another port. If it doesn't work, try the drive on another PC. Check for the power connection cable as well.
Let me know if this works,
levibit
Dec 17, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Preciso dos driver da placa mãe gigabyte ga-6bxc todos os driver
please try www.motherboard.cz/mb/gigabyte/GA-6BXC.htm
best regards
b.m
Nov 19, 2010 | Gigabyte Slot 1 GA-6BXC Motherboard
The memory is locked.how to unlock
you got card unlock system in market which has around Rs200.00 price which is run on battery. you insert your memory card into it and switch on it, then a red LED will on, at that time you will not remove your card, which indicate that your card unlocking process is going on. if the card is unlocked , a green LED will light, then you press the swith that below the green LED and remove your card. if you remove your card before pressing the green switch, your card will lost. some times all the data that stored in your card is lost.
Sep 15, 2010 | SanDisk 2GB microSD Memory Card
LAN not working,i mean that LAN led not blinking.and i fail to connect internet connection.Plz give me suggestion....
try unplugging the cable and insert again ...
check if any lose connection ............... install your lan s/w properly ........
Feb 09, 2010 | Intel Motherboard
The internet providers technical person connected the cable and told me that your lan card is faulty so change it. my lan card is inbuilt on motherboard
Unplug your power cable; Take off your casing cover; make sure your hand is dry and clean, install your LAN Card to the right slot (Please refer to your Network Card Manual Book); Power On your PC, Press Delete at boot screen until u login the bios screen, go to the Advanced Tab on the top there, Select [Disable] for Onboard Lan; Then save & exit. You're done well! Congrat!
Dec 01, 2009 | ASUS M2A-VM Motherboard
I have GA-6BXC motherboard, came with a Pentium II 400 mhz, I upgreded it to a P3 550 mhz,lastest Bios F3 is loaded, ugraded the memory to Kingston ,from there website. No when I turn on the computer I get...
A couple questions:
1) I assume you have the manual. 6BXC Manual
2) Just double checking...the BLACK boxes marked in the manual for the switches are the white switch "levers" for lack of a better term. So switch 1 should have all 4 levers up. (Toward the CPU.) Switch 2 should have the left-most lever down and the other 3 up. Are those correct?
3) The RAM modules have a max of 256MB in each slot. Is that good? (Try with only one module at a time.)
4) Does JP10 have the jumper on pins 2 and 3? (Page 16)
5) Is the battery good?
If all that is good, clear the CMOS. See page 17. Take the jumper from pins 2 and 3 and place it on pins 1 and 2 for about 15 to 30 seconds. Then place it back on pins 2 and 3. Try to reboot.
Also, what kind of graphics card are you using?
Awaiting your response.
Wayne
Nov 25, 2009 | Gigabyte Slot 1 GA-6BXC Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Gigabyte Slot 1 GA-6BXC Start Up UnStable
I recommend that you formatt your HDD to a FAT32 system probably by using another pc then you should also ensure that your bios is setup for the appropriate operating system. maybe just download the appropriate bios files off the gigabyte web site.
May 27, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
Gigabyte Slot 1 GA-6BXC Motherboard Logo
105 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
