Question about HP LaserJet P3005n Printer
Duplex option is not there.
In 3005n printer i cant find Duplex option in configuration menu. Is this model support Print both sides?. please help me!
    Problem Solver:
  • 5 Answers
When you have a P3005n, you probebly see a duplexer unit in the printer, but it will not work, because you haven't P3005dn/P3005X!
Posted on May 22, 2008
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
What is it wanting me to do when it says "install duplex unit"?
A duplex unit allows you to automatically print double sided jobs. It sounds like a duplex unit is an option on your printer. If it is asking you to install a duplex unit, it is either configured for duplex printing i.e in your printer setup, duplex printing is enabled or, your driver has two sided printing enabled as its default.
Hope this helps.
Jan 22, 2011 | Office Equipment & Supplies
How do you print double sided on the HP4015x printer?
Hello, The preferred method is to select Double Sided (duplex) printing, is from the print driver.
From a standard windows enviroment.
To perform the following task, open the printer driver and click the "Finishing" tab.
Click "Print on both sides". If you will be binding the document along the top edge, then select "Flip Pages UP" Another way is to setup the printer from the control panel. Press the "menu" button on the control panel - navigate down to the "configure Device" sub menu, navigate down to the "duplex" option On/Off. The link below will take you to the opeators guide manual.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Jan 13, 2011 | HP P4015X LaserJet Printer with Automatic...
In the past I was able to choose the Manual Option which allowed me to print on both sides. Now every time I choose this option, it goes to Off. Can you please help me with this problem?
Many printers support duplex printing, but they don't all make the duplex option available in the same way. With some desktop printers, choosing duplex means that the printer prints all of the copies of the first side of a page, then pauses and asks you to flip the sheets that it just printed and return them to the printer, after which it prints all of the copies of the second side. This method is called manual duplexing.
To print on both sides of a sheet of paper:
  1. On the File menu, click Print.
  2. In the Print dialog box, in the Name list, select the printer that you want to use.
  3. Click Properties.
Note The information in the Properties dialog box varies depending upon the manufacturer of the printer you're using. With some printers, you will see a Layout tab with a Print on both sides option on it. With other printers, you might see a Features tab, and the duplex option might be called something like Two-sided printing. Explore the various tabs in the Properties dialog box until you locate the duplex printing option.
  1. Choose the duplex printing option that you want.
The options will be called something like Long edge (or Flip on long edge) and Short edge (or Flip on short edge). Whether it's better for the paper to be flipped on the short edge or the long edge depends upon the type of publication you're printing. You might need to print a test publication or two to discover which option works best.
  1. Click OK to close the Properties dialog box, and then click OK again to close the Print dialog box and print your publication.
Sep 25, 2010 | HP Deskjet 2460 InkJet Printer
My HP 4700 printer suddenly can not print on both sides, yet it used to print on both sides. I can't see the option for duplex on its printing menu. Pls help
You can enable duplex printing from your computer, if it somehow got turned off. Open the printer program, and under Configuration Settings, click Duplex Mode, then click Enable Duplex Mode and then Apply.
At the printer, you can find the Duplex options by clicking Menu and scrolling down till you see Configure Device. Duplex is in that menu.
Aug 06, 2010 | HP LaserJet color laser printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Double sided printing
Firstly ensure that the duplex unit is installed by going to start - Settings- Printers and faxes.
Then right click your printer and select properties. Select the last tab at the end of the properties screen which reads "Option"
Then under the options where you see the Duplex unit option select "Installed" from the drop down menu.Click Apply and OK
Alternately you can insert the ip address of the printer and select the gather option information...
Now for double-sided/duplex printing
1. Open the document you want to print eg: MS Word
2. Click on the "file" menu select "Print"
3. Then Select the printer from the drop down menu
4. Click on the "properties" box next to the printer you selected
5. In the first screen on the "Setup" tab find the Binding option and select at the Print type "DOUBLE SIDED"
6. Click apply and this will enable double sided printing.
7. you can leave the binding position on "Auto"
Hope this helps
Regards
Rene Fernandes
Feb 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Printing on both sides
Check the printer setup and configuration to make sure the duplex option shows up as installed. If not, install / add the option from the option list, and this should return the duplex option to availability. If it doesn't show up in the option list, then the computer is not recognizing it as being installed in the printer, and we will have to look further as to why.
Oct 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
HP LaserJet P3005n Printer Logo
319 people viewed this question
Seeker5211
Seeker5211
