Question about Videoseven Slim Line L15CM (White) 15" LCD Monitor
What voltage power cable/transformer do i need for an "EXtreme" monitor
Hello, I really need some help. I have posted about this once and was offered general advice suggesting I try to find a repair man, which though appreciated didn't really help all that much.
I have recently been given a monitor without a power cable that appears to need an independent power supply.
Though it is branded as being "EXtreme", it is hard to say what make of monitor it is, as a reasonable attempt at searching on line has not yet yielded anything conclusive.
There is some information on the back of the monitor. Here it is.
L15C
100 - 240VAC 50/60Hz 1.5A
15" TFT LCD MONITOR
S/N:
W149000087
Model ST - 15V
The socket on the back of the monitor is labled DC IN.
*What I would like to know is: what type of power cable/transformer do I need and more specifically, what voltage should it be (this is the piece of information that for some reason is missing. I have taken it to a shop and was told that without this information there was a chance that the monitor would be wrecked by gambling on the voltage and trying an incorrect cable).Most monitors seem to be in the range of 9 to 15V but as I am somewhat inept with electrical devices I do not wish to assume a general truth, nor do I know whether I have to find an adaptor that is exactly right or simply works within this or a paricular range.
It may be that I am just being a bit slow but if you could think of anything that would be of help I might stand some chance of getting this thing going. As you may have guessed, I am not what you would call an expert so please be patient with any explaining.
  • Samizdat Apr 02, 2008
    Thanks for that Geno. That does seem to make some sense.
    Everybody we have shown the monitor to (people in computer sales and supplies, engeneers in internet cafes, electricians working in electrical shops etc) seems united in their confusion at both the information that there is and the information that there isn't. Most other monitors of an apparently similar spec seem to be 12V. In the end, like me, nobody is particularly willing to try anything.
    Master:
  • 518 Answers
I don't know why it specifically say 100 - 240 VAC (That's AC Input), then label the jack as DC IN. So I'd guess it will run on either. Is there a jack or connector for the AC in as well? Most DC inputs are indeed around 12 Volts, this is so they can be operated on vehicle voltage.
Hope that helps a little...
Geno
Posted on Apr 02, 2008
What is "flyback" on tv monitor
the "flyback" is the VERY high voltage transformer that powers the CRT through a cable that plugs into the CRT inside the monitor case. Don't try unplugging, even with power off, as it has to be discharged to ground to remove risidual voltage, like a capasitor. This voltage is about 35,000 vdc.
Dec 01, 2013 | Samsung SyncMaster 793DF 17" CRT Monitor
I have the power 8030 that I bought in London. I've been using them with my step up & down transformers. I moved to another studio and a kept the same configuration but now the wont power up using...
Compare the power inout voltage listed on the BACK of the speaker and compare that to your current power supply. You have not told us wheree you are or what your power there is... or the voltage listed on the back of your speakers. Giv us this info so we can better help you. These are expensive speakers to get things wrong...
Sep 12, 2011 | Genelec 8030.LSE Power Pak Active...
Hello, I am trying to fix the monitor LG L1951s that does not power on, I found the 68uF*450V capacitor bad, replaced this one but problem ramains. I have measured most of the componets on the power board...
The 68UF 450 is for the primay smps driving side, are you getting about 160vdc on that cap?
The PWM IC get the kick start DC voltage from the main bridge rectifier thorough a bunch of high resistance resistor to drop the 160vdc down to aboit 15vdc, once the PWM IC start working, one the winding will be the supplying the voltage to the IC to keep it running. If the DC output side detect short cirsuits (drawing too much current) it will go into shutdown, you need to find out if the inverter circuits has short circuits. The 5vdc and the 12~18vdc power supply will be running the minute you plug it in, you can solder in a 12v bulb at the DC output that feeds the inverter circuits (you can solder it directly on the DC filter caps for the 12~18 VDC filter caps of the inverter circuits). See application notes how this IC is used.
http://www.fairchildsemi.com/an/AN/AN-4129.pdf
http://www.fairchildsemi.com/ds/FA%2FFAN7601.pdf
No blown MOSFET on the primay side?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 21, 2010 | LG L1951S-SN (Silver, Black) (Black,...
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
Mar 08, 2010 | Sony Computers & Internet
Where are the inverter transformers on a E173FPc circuit board?
The transformers are the 2 rectangular parts on the power board. If you go to our web site at: www.ccl-la.com we have a step by step repair guide to the Dell E173FPc monitor. If you open your monitor and look at the power board the back lights plug onto the board by the transformers ( the cables will be either pink/white or blue/white ) If you need any more information about repairing this unit just contact us through our web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 11, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Will not power up
Hi there.
Have you checked the powersource? Is the transformer working?
Is the cable from the wall socket to the transformer broken? Is the cable from the transformer to the screen broken?
Is the plug on the same cable damaged?
Is the transformer the right size( voltage)
Is the polarity on the screen plug right?
Is the screen actually working?
Iceman.
Nov 04, 2009 | Samsung SyncMaster 720N Monitor
What voltage do i need for my ViewSonic VA720
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
Oct 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Belinea 10 19 20 power issue
Honestly the power supply uses capacitors to build up the high voltages required to run the monitor display. In all high probability one or more of these are failing and they are discharging to rapidly not allowing enough voltage to the display transformer. It won't come on until voltage is high enough. You're gonna need a new monitor soon, If you can obtain a schematic you can check the voltage drops across the output transformer and replace the faulty component but it is very time consuming and hard to get board components these days for digital supply boards in the states. Sorry I could not be of more assistance.
Mar 29, 2009 | Belinea 19" LCD Monitor
Hp Pavillion F1703 17 LCD monitor
Yes, the connector next to the speaker connector is for the power adapter. It's different from the speaker plug so you can't put it in the wrong place. Hopefully you got the right power adapter with the monitor.
Here's the page at HP's site where you can download the User's Guide for this monitor. Hope this helps.
Jan 29, 2009 | HP Pavilion F1703 17" LCD Monitor
Unknown cable voltage for a computer monitor
Although this may sound like passing the buck, but search for a specialty LCD repair company. Hundreds of these companies exist.
Apr 01, 2008 | Videoseven Slim Line L15CM (White) 15" LCD...
Videoseven Slim Line L15CM (White) 15" LCD Monitor Logo
102 people viewed this question
Top Videoseven Computers & Internet Experts
Alun Cox
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
