Question about Seagate (ST3160827AS) 160 GB Hard Drive
Patition accessing problem
Every time I want to access HDD ,it shows an error that sys.exe is missing
  • Anonymous May 11, 2010
    What operating system?
    Geno
    Genius:
  • 1,011 Answers
Hello Sir/Madam,
Sys.exe is a process associated with the Backdoor.ICR Trojan. It is a trojan that gives remote users unauthorized access to the system. It is controled using ICR ( Internet Relay Chat ). This program is a registered security risk and should be removed immediately. If found on your system make sure that you have downloaded the latest update for your antivirus application.
Good Luck
thanks
Don't forget to rate the solution.
Posted on Apr 02, 2008
SOURCE:
My alienware with windows7 will turn on but has a missing operating sys message. I can't start it in safe mode.
In the bios see if you can run a HDD check/scan.
Do you have a Windows 7 recovery disk (DVD)
If you do boot from the recovery disk. you should be able to recover the OS.
Or even use some tools to check the HDD (Hard Drive)
Normally this can either be a corruption, or a failed HDD.
Apr 03, 2014 | Alienware PC Systems Alienware Area-51®...
Error missing ntfs.sys
Boot off the Microsoft Windows XP Pro CD. Repair the Windows installation.
Take care!
damnor01
Apr 28, 2012 | E-Machines eMachines Desktop PC
I tried to install Singer PSW2.00a on Windows 7 and I get the following messages: {c121466d-3abd-445a9eeb-13479378a9ae}/Install.exe could not be installed access is denied and error in...
Run the install.exe on the disk as administrator, even when it automatically does that, you still have to do that. If that doesn't work, contact Singer.
Apr 13, 2011 | Singer Professional Sew Ware Options 2.0...
I bought an USB Celcom Broadband (HSUPA USB Stick (Model: ZTE MF190) a few days ago. I installed to my Ftec laptop (OS : Windows XP Pro SP3), but can't use. There are messages appears : (1) Exception...
hi sir,
i got a problem regarding the celcom broadband. the problem was happen since yesterday. i left my notebook for along time (may be about 20 hours) where i am not to turn off the celcom broadband. when i come back and see to my laptop, it's already shutdown. when i turn on the laptop.. the error problem pop up at my laptop screen. the error shows :
access violation 004A1170 in module UImain.exe. Read of address 0000051c'
please help me to solve the problem. i cannot access the broadband as previously. Thanks :(
Oct 08, 2010 | Microsoft Windows XP Professional With...
Problem message at startup. Exception Eole sys error in module wcomschd.exe @ 00056E01. error accessing the OLE Registry,
it can be enabled or disabled by the option in the system properties and under the advanced tab and option named as error repoting
Feb 12, 2010 | Computers & Internet
How to solve pci.sys error during reformating of the hard drive
You have two ways to solve the problem of "Pci.sys Is Missing or Corrupt"
Error Message When You Start Windows.
1.Booting with WinXP CD to access the Recovery Console’s Repair option,
and then copy from WinXP CD the missing or damaged Pci.sys file to
Systemdrive:\Windows\System32\drivers folder , Exit and Reboot.
start the recovery console and type:
set AllowAllPaths = true
expand d:\i386\pci.sy_ c:\windows\system\drivers32 /y
If you don't type
set AllowAllPaths = true you can't access the windows folder.
2. Booting with WinXP CD and then perform a Windows XP Repair Reinstall
of the currently installed system.
If you need detailed assistance post with details of your Operating system
[WinXP Home vs WinXP Pro and the SP status i.e SP1 or SP2 ]
See
http://support.microsoft.com/default.aspx?scid=319136
Jan 12, 2010 | Microsoft Windows XP Home Edition
USB HDD not showing in My Computer
It could be that the USB port on that computer is not delivering enough power.  Will your Drive accept external power?
May 12, 2009 | Computers & Internet
Error reading patition table (MBR)
well am not 100 pct sure but i Guess u need to restore ur mbr /track 0 sector 1
[email protected]
Sep 16, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Cisco error on switch
%SYS-4-P2_WARN: 1/Tag 0 The switch generates %SYS-4-P2_WARN: 1/Tag 0… messages.
This example shows the syslog output that you see when this error occurs:
%SYS-4-P2_WARN: 1/Tag [dec] on packet from [ether] port [chars],
but port's native vlan is [dec] This message indicates that an 802.1Q-tagged packet was received on a nontrunk port. The VLAN that is derived from the packet tag is different from the port native VLAN. In the error message:
  • The Tag [dec] is the VLAN identifier from the packet.
  • The [ether] is the host MAC address.
  • The port [chars] is the port identifier.
  • The second [dec] is the native VLAN number.
There is a possibility that the local port is incorrectly configured as an access port instead of a trunk port. Alternately, the remote side can have been configured as a trunk port instead of an access port.
Verify that the local port is not incorrectly configured as an access port instead of a trunk port. Also, verify that the remote side is not configured as a trunk port instead of an access port.
Feb 06, 2008 | Cisco Catalyst 4006 Chassis ( 4006)
Open Questions:
bxshhj AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 20, 2019 | Amazon Computers & Internet
^%#@*& Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
See all Seagate (ST3160827AS) 160 GB Hard Drive Questions
Seagate (ST3160827AS) 160 GB Hard Drive Logo
63 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
