Question about Oregon Scientific WRS101 Weather Radio
We have an Oregon Weatherstation Pro Model BAR629HGU. It says this product will desplay minimum and maximum termperatures etc. For what time frame does it record maximum minimum temperatures and how do I zero the unit to view maximum minimum temperatures daily? Lloyd.
It records the highest/lowest readings since you last reset it. To reset, hold the memory button for about 2-3 sec.
Try this link for a manual:
www.oregonscientific.co.uk/files/manuals/BAR629HG%20-%20Easy%20Weather%20System%20Pro.pdf
JP
Posted on May 05, 2008
SOURCE:
Is There A Required Minimum Or Maximum Factoring Volume?
suggest you check with the publishers tech support
Aug 05, 2016 | Computers & Internet
#the alarm keeps bleeping and unable to switch it off unless I remove a battery.
Use a volt meter to see if the battery is depleted or not. If you replace the battery and the alarm stops then it was a weak battery, If it keeps on then there something setting it off. You can use the information in the owners manual Oregon Scientific BAR629HGU Manuals to troubleshoot it.
Jul 10, 2016 | Oregon Scientific Measuring Tools &...
Why is the time on my weather station always 3 hours behind
You need to set up the correct time zone offset. For example, CST is -6; EST is -5. If daylight savings is active, time will be: CDT = -5; EDT = -4.
CST = Central Standard Time
EST = Eastern Standard Time
CDT = Central Daylight Time
and so on.
The Official NIST US Time
Aug 27, 2014 | Oregon Scientific WeatherStation...
Cl-935
This model number does not appear to relate to Oregon Scientific. Look at these two manuals: they may answer your question: http://www.manualslib.com/products/Oregon-Scientific-Eb313hg-294871.html
Aug 03, 2014 | Oregon Scientific Handheld Weather...
Need to order new 16" chain for my remington chain
Hi mariam608...
Go to HomeDepot and you can buy one off the shelf.
You can also order it online at:
http://www.amazon.com/Oregon-S56-Craftsman-Homelite-Remington/dp/B00004RA82
It will be made by Oregon...P/N S56 low profile...
It will fit your Remington Electric and other chainsaws.
Please take time to rate me
Sep 07, 2011 | Remington 16" Electric Chain Saw
Minimum memory of laptop?
The specification does not tell you the minimum memory. If available you may put 64/128/256/512MB DDR2 667 MHz ram. But these days minimum ram size available in the market is 1GB DDR2 667MHz ram. So this is the minimum.
The most important is the maximum memory it can support. This model can support maximum 2GB DDR2 ram.
Jan 18, 2011 | Fujitsu Siemens ESPRIMO MOBILE V5515...
What is the toe adjustment for a 1998 ford windstar 3.8L
Hello Snsimpson
Here are all the specs for the Windstar.
FRONT ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal -0.25°
Minimum -0.75°
Maximum +0.25°
Split 0.0°±0.5° Caster
Right
Nominal +3.80°
Minimum +3.05°
Maximum +4.55°
Split -0.5°±0.5° Left
Nominal +3.30°
Minimum +2.55°
Maximum +4.05°
Split -0.5°±0.5° Total Toe [1]
Nominal -0.10°
Minimum -0.40°
Maximum +0.20° Clear Vision [2]
Nominal -0.2°
Minimum -2.8°
Maximum 3.2° REAR ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal 0.0°
Minimum -0.3°
Maximum +0.3° Total Toe [1]
Nominal -0.06°
Minimum -0.40°
Maximum +0.28° [1] Positive value specifications for toe-in, negative value specification for toe is toe-out. [2] Negative value specification for clear vision is counterclockwise.
Nov 16, 2010 | 1998 Ford Windstar
Where is the fuse inside the power supply model fsp200
The unit is only 200watt and the fuse cost about $2,Thats if there one built into it,
The replacement power supply is about $20-00 NZD
Probably 20minutes to fix (for a novice) depending on their skill level and tools available,
BEST ADVICE Replace it
Power is something you dont want to mess with because it can kill.
The power packs are replaceable but people arent.
Be very careful and dont mess with the power.
I am an Electrician and I respect power.Misterdj
Mar 24, 2010 | AOpen (FSP200-60SAV) 200-Watt Power Supply
Oregon Scientific WRS101 Weather Radio Logo
188 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Tom Chichester
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
