Question about LG RH266 Recorder
How Do We Install
We have gone through the manual on how to set up and receive desired channels, it says it will find 88 and it has only found 10, some of them are fuzzy as well.
I am having problems getting the recorder to recognise that my TV has integral freeview channels...it only seems to recognise the old analoge channels...help please
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
It is probably picking up the airwaves only. Treat it as if it were connected to a satelite dish service. You need to turn the device to channel 2 or 3 (depending on what output channel is specified on the freeview) and from here you can change the channels without having to scan for them. This might be the case but then again, it might not
Posted on Jun 15, 2008
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
How do you hook up a external amp to a yamaha HTR-5790 av receiver? Do you have to change any settings?
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try retrevo.com
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Dec 23, 2010 | Yamaha Audio Players & Recorders
30 channel 10 band radio scanner uniden 8c60xlt
You listed your question under the BC60XLT, which is a 10-channel scanner. With 30 channels, I'm guessing that yours is actually a BC60XLT-1. To program a known frequency into it:
- Power the scanner ON.
- Press MANUAL.
- Enter the channel number that you wish to program.
- Press MANUAL again. (NOTE: Instead of entering the channel number, you can press MANUAL repeatedly to advance to the desired channel.)
- Enter the frequency, including the decimal point.
- Press E to store the information in memory.
- Repeat the above for other channels.
More detailed information can be found in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
If your scanner is a different model, pleasd let me know.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
May 11, 2010 | Uniden BC60XLT Handheld Scanner
I just aquired a Regency R 4010 portable scanner and am looking for the frequency range and programing instructions.
Turn scanner on.
Make sure Key Pad is set to ON.
Press the manual button until the Channel display shows the channel you want to program (i.e. 1 thr 10)
On the key pad enter the freqency and hit the E key when done.
Hit the Manual key to select the next Channel you want to program.
Repeat process.
When finished hit the scan button.
If you want to see what freqency is programmed for a channel hit the Manual button until you reach the desired channel then hit the Review button.
If you want to lockout a channel (i.e. a channel that continuously broadcasts like the National Weather Service, hit the Manual button until you reach the desired channel then hit the L/O button. Hitting it again will unlock the channel.
Jan 29, 2010 | Office Equipment & Supplies
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Box super no channels
Pure ntl codes. 5401
00 A9 5D 4E FE 20 E1 2D 03
01 88 6B 69 7E 94 B6 BB 1E
Press menu on remote, On installation press 1570,On nagrivision press O K, This will take you to the providers,scroll right to yours and using the remote put codes making sure to press store after each set, exit menu after that. you should have all channels then.
Dec 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
How to set presets gpx rdt4004sp
You can store up to 10 channels. For channels 1-5:: Go to station you desire. Press MEM button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels. After you store to buttons 1,2,3,4,5 then: For channels 6-10: Go to station you desire. Press MEM button. Press +5 button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels.
May 31, 2009 | GPX RDT4004SP AM/FM Radio
Scan chennels
Go to Page 10 of your owners manual the section marked "open scan mode allows you to set which channels are in the open scan memory.
Pat N5SLI
Aug 26, 2008 | Uniden Radio Communications
How Do We Install
maybe you'd got a wrong installation of your dvd.
Mar 25, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG RH266 Recorder Logo
81 people viewed this question
Computer Repairing
Computer Repairing
