Question about Hotpoint Ultima WF860 Front Load Washer
Error code f08 on Wt940 ultima.
Hi I have a Hotpoint Ultima wt940 and it is showing the error code f-08? Any ideas on how to fix?
Thanks, Mike.
  • 1 more comment
  • lynsgray Apr 04, 2008
    We have ultima wt746 with error code f-09 then f-03, was working fine yesterday, suddenly stopped today.. help
  • Anonymous Mar 30, 2014
    On a hotpoint w965
    Error code F08 ? Had filter out and cleaned. Error code appears when the hot water pump kicks in?
  • 5 Answers
Not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
  • 32 Answers
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
These errors require you to contact the service helpline given on the last page of this manual
Posted on Apr 13, 2008
How to fix error f-08
if my memory serves me right f08 is faulty heater code check the heater is okay
Mar 09, 2014 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt940 washing machine
Either you dont have a high enough amperage breaker or the motor is going bad
Dec 10, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima wt940 I load washing and set a normal program (say 40 degree wash). The door is firmly closed. I push start. Even though the LCD is on and I have pushed start - there is no...
'door' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
How to remove the top from a hotpoint WT940? 2 Rear screws already removed.
you need to give a sharp blow to the front of the lid towards the rear.. there are keyholed lugs holding it down in place... use you hand not a hammer...lol.. Thanks
Dec 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error F01
i have the same problem the machine gets part way through a cycle and then stops and Displays F1.
Oct 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F-08
The meaning of F08 is that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
In order to resolve this the only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Hoep this resolves your issue. God Bless.
Jul 09, 2009 | Hotpoint Ultima WF860 Front Load Washer
Daughter has ultima wt940 error f-01 comes up any ideas
This refers to motor error, check motor wire connections & brushes. If these are ok it is its a pcb fault which requires replacing & programming.
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
7,508 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
