Question about Car Audio & Video
Car Alternator, 2004 Citi Golf
  • We need to learn how we can connect to the alternator to have a continuous supply of current from the alternator while the engine is running?
  • How do we bypass the regulator?
  • In other words, we need two sources of power from the alternator, one to provide continuous power, two, power to the battery which will stil cut out when the battery is full.
  • Can you help please?
Martin Steyn
    Novelist:
  • 100 Answers
First off, I am curious as to what you need those particular power sources for. Also from my experience regulators don't actually cut out when the battery is full. It actually just stops the amount of voltage at a certain point, in this case 14.4 volts, and stays steady at that fixed voltage. A helpful page could be http://www.autoshop101.com/trainmodules/alternator/alt101.html I think it explains alternators very well. It might not be exactly what you are looking for but I hope it helps. Let me know how it goes.
-Andrew Hawkins
Posted on Apr 02, 2008
How to replace an alternator for a 2001 Nissan Pathfinder XL 3.5
Nissan xterra alternator removal and installation - YouTube
? 2:53
https://www.youtube.com/watch?v=n35OVegqBsg
Feb 7, 2014 - Uploaded by Francisco Delira
2001-2004 Nissan xterra alternator removal and installation removing ... how to replace the alternator on ...
How to Change an Alternator : Removing the Serpentine ...
? 4:02
https://www.youtube.com/watch?v=nJgVJNtZxuA
Oct 18, 2007 - Uploaded by expertvillage
Learn how to remove a serpentine belt with expert car maintenance tips in this fre... ... How to Change an ...
Alternators ' Starters ' Belt Tensioner ' Tensioner Pulley ...
https://www.pepboys.com/parts/alternators_starters/
Pep BoysFind alternators, alternator belts, parts and starters you need at Pep Boys. ... Regulators; Alternator Relays; Belt Tensioners Pulleys; Alternator Repair Kits ...
2001 Pathfinder alternator installation problems - Nissan Forum
www.nissanforums.com/pathfinder/172789-2001-pathfinder-alternator-i...
Dec 14, 2012 - 10 posts - ‎3 authors
Dec 03, 2015 | Nissan Cars & Trucks
Aircon belt snapped, can i still drive my citi golf
It won't hurt the AC compressor. As long as the belt doesn't also drive the water pump or alternator, you should be fine without the AC belt.
Dec 31, 2013 | Cars & Trucks
My golf kills the battery every time even if the car is off
for the battery to discharge when everything is off is a clear indication that you have a circuit not controlled by the key. Find out the current used by disconnecting the positive terminal of the battery and connecting an ampmeter in it place so that you can read the current from the battery through the lead. If it small 1-5 amps check for a light on IE boot light that is not switching off because it needs adjustment. If the current is higher then I would suspect something like the alternator lead Attached to the battery lead to the terminal on the alternator. This lead is always alive and is prevented from working because of the diodes in the alternator. . If one is allowing a current flow through the alternator or you suspect that it is disconnect the lead from the alternator over night and look for a response. Ensure the lead is properly insulated as if it is allowed to touch earth it will burn the lead.
Jan 24, 2013 | Cars & Trucks
The car is shutting off after starting then draining the battery. I have tested the battery and it is still good. Is this an alternator problem or something else?
Yes, the majority of vehicles can be started and then the battery completely removed from the vehicle and continue to run. If your Jeep dies and then wont restart (or is hesitant) because of a dead battery, this would most likely be the alternator connections, or event he alternator itself. Obviously the alternator is not supplying current to the vehicle. Most autopart stores can check the alternator for you, often free of charge and the easiest placed to start.
Dec 19, 2010 | 2004 Jeep Wrangler
How to tell if the battery or the altenator is bad
Test the car battery & the alternator supply voltage. If the alternator voltage is around 14 Volts, engine idling and headlamps low beam turned ON, then the battery is bad. After engine stopping, the battery voltage should be at least 12,4 Volts. The battery could be too old and needs to be replaced. If the alternator voltage is below 13,8 Volts then you must check up first time the alternator belt & tensioner pulley. If everything is OK, then the alternator is out of order and needs to be repaired in a dedicated workshop: weared brushes, bad voltage regulator, ...
Oct 08, 2010 | 2003 Volkswagen Golf
Can you hook your amp straight to your alternator with no problems
Hi TW,
Please ignore the post here by 79 as anything but fiction.
An alternator produces DC current not AC. It does however fluctuate quite a bit. It's the low voltages that will stop your amp from functioning.
Whether you connect your amp to your alternator or your battery doesn't matter. They are connected to each other already. The battery stabilizes the current to your amp. When the amp requires more than the alt can supply, the battery fills in.
Personally, the battery is easier to connect to.
Best regards
Mike
Feb 21, 2010 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Hi, problem with 2007 VW Citi Golf radio security code.
The radio is in Lock-Out mode. You only get two attempts to enter the code, then it enters Lock-Out mode.
Put the key in ignition and turn on the radio for an hour (maybe a bit more). The radio should reset itself after about an hour and then you can re enter the code.
Jul 08, 2009 | 2007 Volkswagen Golf
Remanufactured alternator (for a 1995 BMW 325is) humming
It sounds like one of the high-current diodes has failed and the rest of the alternator is trying to supply current into a shorted diode. Any chain auto parts store will check it free if you remove it.
Jun 06, 2009 | 2004 Jaguar XJR-Series
Car Alternator, 2007 Citi Golf
the citigolf needs to have relays changed.
Jun 02, 2009 | 2007 Volkswagen Golf
2004 Hyundai Elantra problems after replacing alternator
Sound to me like some wires were either disturbed or crossed and are shorting out maybe when you replaced the alternator?Maybe have a look at the alternator connections again and make sure everything is correct and tight and that the new alternator is the right one for your car.Other than that its a case of tracing the wires from the alternator to the fusebox to find whats blowing your fuse.
Jan 01, 2009 | 2004 Hyundai Elantra
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
