Question about SAMTRON 55V 15" CRT Monitor
Powering up problem on UPS
I have an APC Back UPS ES having an output power capacity 300Watts / 500 VA. Sometimes while listening to music on my PC, I switch OFF my Samsung 55V 15 in. monitor (Only the CPU keeps running) . Under this condition if the AC power supply is cut off and the UPS battery takes over, if the monitor is switched on just to shutdown the PC, there is a click sound in the UPS and my computer RESTARTS. Obviously this is happening due to high power consumption during startup of the monitor. My question is whether this is normal and happens with any monitor and UPS ?
One more question is will this problem be solved if I get a TFT monitor ? I'd like to buy a 19 inch TFT monitor.
Thank you very much.
    Genius:
  • 2,785 Answers
About your first problem it is not normal.you should check it out with a qualified professional.
after repairing it will work nicely
Posted on Apr 02, 2008
SOURCE:
Why no OMNIVS1500XL power?
you have 3 output connectors connected to battery back up ( there is output when input power fails
other 3 sockets are connected to main power / when main power off , no output on the mentioned connctors
May 13, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Apc ups not powering on
hi,
check the battery voltage. if it is bellow 11v this problem can occur. apc ups starts from its battery and then only it gos to mains supply. if ur battery is deeply discharged it will not power on. in this case u have to pullout the battery from ups and charge it using battery charger. if not works replace the battery.
Dec 17, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from apc.com
Jun 25, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
It does not power on
Ok there could be a whole mess of reasons why but let me break down a few okay.
1. Bad battery
2. bad fuse
3. cord could have gotten burned inside (overload)
But guess what? If you called APC I bet they will ether take care of you or give you a discount on a new unit I have done this with them there a good company that does listen.
Let me know ether way.
For this free solution please do be considerate and rate it and leave some feedback, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 29, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
UPS shuts off intermittently and beeps
More than likely it just needs a new battery. If the power is sagging (called a brownout) the UPS is trying to switch over to the battery to keep the power consistent. The beeping is probably a code that indicates there is an issue with low voltage on the battery. New batteries are around $20-25. Here's a link to the replacement battery: http://batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Hope that helps.
Jan 21, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
APC Back-UPS ES 350 - when powered on has a blinking green light Is this normal
A blinking green light is likely an indication that the internal battery is nearing the end of its usable life cycle. If it's over 3 years old this is likely the case. To test, plug something in to the battery outlets and pull the plug of the UPS from the wall. If you get a short runtime (or none at all) it's the battery. Batteries are under $20 and can be found here: http://www.batteryinternational.com/apc-backups-es-be350u-ups-battery-ups-batteries-f1.html
Oct 06, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
APC UPS issues
If its really a noise? neutral and ground of your utility power (building transformer) should be bonded
Apr 14, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
APC ES350 strange noise
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Sep 28, 2008 | APC Back-UPS ES 350 - UPS ( external ) -...
SAMTRON 55V 15" CRT Monitor Logo
Top Samtron Computers & Internet Experts
William Miller
William Miller
Ekse
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
