Question about Gigabyte GA-6WMMC7 Motherboard
Not starting After 4years GA 6WMMC7 motherboard does not start up, the cpu fan runs,hard disk does not spin,screen stays blank
  • 53 Answers
Hi ,
Have u tried?
First u clear the cmos means beside the battery there is one jumper with 3pins (2 pins are shorted with jumper)
U put the jumper in 2,3 position in system off mode keep some sec's time and kept the jumper as usaual.
Then u check the system ,if no display pl change the PSU
Pl try it
Was this soultion useful ?show ur appericiation by rating it
Posted on Apr 02, 2008
PRECISO DO MANUAL DA PLACA MÃ?E GA-6WMMC7 REV5.0
Pruebe aqu?: -
http://ee.giga-byte.com/products/mb/manual/ga-6wmmc7-1.html
Nov 25, 2010 | Gigabyte GA-6WMMC7 Motherboard
Need user manual for ga 6wmmc7 motherboard rev2.3
You can find the user manual for your product here.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 28, 2010 | Gigabyte GA-6WMMC7 Motherboard
Blank screen slow coming on md6 model 7700 fan was excesively noisey before pc stopped coming on all together, almost 4years old any ideas please?
It sounds like the CPU fan has failed and is causing the PC to overheat straight away.
To determine if the CPU fan has failed you will have to remove the side panel from the desktop and check the fan.
If the fan is caked in dust try cleaning the fan blades and the metal heat sink with a clean dry paintbrush, then try turning the PC on to see if it makes any difference.
If it still does not come on or it comes on but the fan isn't rotating then the CPU fan will need to be replaced.
If there is still no power to computer then chances are that the CPU itself or the motherboard has blown.
This will mean a new computer or replacement motherboard.
Regards.
Nov 27, 2009 | Medion Computers & Internet
Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Sep 10, 2009 | Gateway T-1625 Notebook
Blank screen on start up
Try removing all cards with the exception of the video. Remove all memory leaving (1) to boot from.
Disconnect power and reset the processor.
If you have a boot disk or copy of XP on disk, try to boot from the CD or DVD.
If the unit boots at all the problem may be the HD.
If not try downloading the BIOS update for your chipset.
Remove all extra drive, like secondary CD or DVD drives, Floppy or Zip drives.
You may have burnt the processor but I don’t think so.
Power supply is OK or you would not power up. Their are 3 or 4 supply voltages from supply, +- 12 volts, +- 5 volts and +-3.3 volts.
You may have a secondary 12 volt 4-pin plug but that is for on board video.
Try a boot disk and flash your BIOS, if you can.
Hope this helps.
Jul 26, 2009 | Gigabyte GA-M55plus-S3G Motherboard
No display by gigabyte GA8i915me motherboard
It sounds like your CPU might be overgeating. Check the CPU heatsink fan to see if it is spinning. Also, make sure that you clean out any dust, as this can lead to overheating also.
Jan 23, 2009 | Gigabyte GA-8I915ME-G Motherboard
GA-7VRX Motherboard won't boot
Hi sebaswis, am I correct that this Gigabyte GA-7VRX is a replacement MB? (I read your other posted questions). http://www.fixya.com/support/t1399506-computer_boot_when_power You mentioned you put your old system back together & it worked fine. If mother board is shorted to the system case you will see the CPU fan spin for a second. Most motherboards use a green led which represents there is stand-by power running to the board.(This is normal). I am unsure why your led is orange. (Its not mentioned in your manual & manual does not show the led?s location). Was the other GA-7VRX MB led always orange or was it also green? Suggest you disassemble the heat-sink from the CPU. You mentioned you installed a new XP 2500+ CPU. If a pin on the CPU was bent during installation of CPU into the socket or if no thermal grease was applied or too little to the top of CPU, either would give you: CPU fan spins for a second & nothing else seems to run. Look over the link provided below. It is a guide to how to install a motherboard. (You may not need this but Its worth going over all the steps). http://www.hardwaresecrets.com/article/145 As far as the power supply. If the MB's are the same (GA-7VRX) & the old system ran with 220W, the newer one should also function. Clarify these questions for me sebaswis. Mike
Dec 18, 2008 | Gigabyte GA-7VRX Motherboard
Pc boots and stays on the black screen at the start
Try getting into the BIOS and making sure that it is detecting the RAM and HDD and Processor. Typically this happens when theres no memory or a memory problem. If its the Hard drive it will say NTLDR missing or Hard Drive failure. When its blank.
Does the Hard drive fire up when its sitting there? Does it seem like it booting the Hard drive or does it just sit there.
Also, if you have an onboard Video and a video card, try using just the onboard video for now, sometimes the Video card can cause an issue if it doesnt have drivers and comes up blank.
Make sure the bios has the video set to PCI or AGP depending which you have intstall. Or Auto if it has it.
I have had two Gigabyte board and im using one now and have had similar issues that where caused by a ATI video card.
Good luck and let me know if you still need help.
Dec 02, 2008 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Please help
The first time I installed a new motherboard I did not realize there were two power cables, one has a small square connector and the other a long rectangular connector. Did you connect both power cables?
Nov 27, 2007 | Gigabyte GA-8S661FXM-RZ Motherboard
Gigabyte GA-6WMMC7 Motherboard Logo
132 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
