Question about Freezers
Philips whirlpool AFG 027 freezer
Large philips whirlpool freezer. i have bought second hand but have no manual. need to know which lights at the front should stay on. there is a push button which is orange but dont know if this should stay on and if the other lights should be illuminated.
  • 3 Answers
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Posted on Jan 03, 2009
    Novelist:
  • 184 Answers
IT SOUNDS TO ME LIKE YOUR FREEZER HAS AN ALARM FOR TEMPERATURE. THE ORANGE BUTTON MAY TURN THE ALARM ON AND OFF. ONE LIGHT WILL BE A POWER INDICATOR LIGHT AND THE OTHER THE ALARM ON INDICATOR LIGHT. IF THE FREEZER IS WARM AND YOU TURN ON THE ORANGE BUTTON, A BUZZER SHOULD SOUND. ONCE THE TEMP GETS DOWN BELOW 10 DEGREES, THE ALARM SHOULD STOP.
Posted on Apr 05, 2008
6ya staff
SOURCE:
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
Feb 10, 2015 | Whirlpool 10 cu. ft. / 283 liter Chest...
Free manual for ELECTRONIC A CLASS Whirlpool AFG 8060
I need a manual for my Whirlpool A Cass Electric Freezer, where can I obtain one from
May 29, 2012 | Freezers
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
Dec 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I have a Lemair FR 120V freezer and I need to know what the buttons inside the freezer represent,
Could anybody please tell me what the colored bottons for this freezer mean. I just got one second hand, plugged it in and there is a red light on. There is also a botton with an S and a circle with a line. I'm guessing that might be on botton but I don't know for sure. It hanks to anyone willing to help!! :)
Nov 05, 2010 | Freezers
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Temperature Control
check if that condenser's dirty first. i suspect that... try that first
Dec 23, 2007 | Freezers
Freezers Logo
2,086 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
