Question about KitchenAid KTT570 4-Slice Toaster
Toaster is not working. It is not holding the bread when pressed down
  • kathie b Sep 11, 2008
    Toaster lever won't stay down, won't "catch" even after repeated tries.
SOURCE:
  • 3 Answers
SOURCE: tfal 2-slice toaster repair
look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Posted on Feb 27, 2008
  • 71 Answers
SOURCE: My toaster is hung up on '2'...and flashes. I just want a peice of toast!
Certainly seems like it's last day has gone!!
It did give you good reliable service didn't it !!!
Posted on Jun 04, 2008
  • 52 Answers
SOURCE: bread will not stay down
Be sure the temp/time dial is not on zero.
Posted on Mar 11, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
SOURCE: Expensive toaster doesn't work
I broke mine trying to fix this, but the fix is very easy. remove the out shell and you will see two prongs with contacts that engage when the plunger is pressed. The plunger will not stay down because the prongs are bent and/or dirty. clean the contact, push the prongs closer to the contact and that should do it. Becareful about how you disconnect and reconnect the wires. That is the mistake that I made, and the fuse blew. BTW, if you fix yours, please let me know what kind of fuse is on it. The fuse is in a sheet in a cluster of wires between the two plungers.
Posted on Feb 16, 2010
My breville toaster model BTA840XL won't drop the bread in for toasting
If your power-socket is off, it won't. (I've done it several times, foolishly cursing the toaster). :rolleyes:
Otherwise unplug from wall, remove covers, check by pressing base down with a pen etc. On most auto-eject toasters, a powerful electromagnetic solenoid (electric magnet) holds the base (slice carriage) down while cool and warming up. When preset temperature is reached, solenoid is de-energized, releasing its magnetic hold on the base, allowing springs to pop bread up.
If you (or friend) has a tester and expertise, check solenoid (small coil) for resistance. If OK, (not open circuit), problem is in control circuitry.
Dec 18, 2016 | Breville Kitchen Appliances - Others
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Black & Decker Toaster, model 3550: Pressing the handle down to lower the bread and start the toasting doesn't lock in place anymore. The toaster will toast, but you have to hold the handle down so...
The fact that pressing down the lever fails, means the toaster contact will not function and can not be repaired. Since a two slice toaster is only $15 at Target, why bother fixing a toaster?
Feb 20, 2018 | Black & Decker Toast-It-All Plus T3550...
What is back to basic toaster?
Toaster of the first order wherein there is only the heating coils arranged on either sides and the bread is loaded on the slits to be pressed down to hold on.
When the set temperature is reached then the bimetal switch releases the lock and releases the bread up.
This is the basic model with no electronics inside.
Aug 25, 2010 | Back to Basics Kitchen Appliances - Others
Help with toaster. anyone there?
Well, I'm not a toaster pro, but I do make my fair share of toast.... I have an idea for you, I researched your product and couldn't find any specific help but try this:
Unplug your toaster, firmly hold the mechanism in the down position as far down as it will go, then turn the unit upside down, give it a good shake and flip the lever a bit. Reinvert, plug it in and see if you've got any improvement. (I think I learned this trick from the Andy Griffith show... you know old Emmett and the fix it shop) let me know if it worked! Sorry I can't be more help.
Dec 12, 2009 | Rowenta TL900015 2-Slice Toaster
Lever on toaster will not stay down
For what it might cost to fix it buy a better brand of toaster for about 10% of the cost of this horrible brand.
You'll notice their new ones are "smart" toasters with NO LEVER. You push a button and the electronics takes care of the rest (and blow up quickly.)
$15 to $25 at Walmart.. instead of $100 to $200.
Dec 13, 2017 | Breville Kitchen Appliances - Others
Aug 04, 2009 | Kitchen Appliances - Others
Tfal 2-slice toaster repair
Feb 26, 2008 | Tefal Avante Deluxe 4 Slice Toaster
KitchenAid KTT570 4-Slice Toaster Logo
77 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Archie Ferrarini
Archie Ferrarini
MARLON KELLER
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
