Question about Sony Cyber-shot DSC-H5 Digital Camera
Memory card I've got sony H5 cybershot camera. I've just bought a 4 GB sony memory stick duo pro but when I insert the card in the camera the light in right corner appears as red and the screen stays black and it looks like the camera doesn't work with it. When I take the mem card out the camera turns on fine. I really don't know why this is happening. Could you help please? Thank you in advance. Regards Radka Hajkova
    Problem Solver:
  • 17 Answers
Dear friend.
here its a problam in mem card or a sellaction of format try to fromat yr mem card in fat16 format and then try with this methord..
don't forget to vote me.. thanks advance.
jo_chinmay
Posted on Apr 02, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Can I import camera pics to a Dobly Home Theater laptop, by Acer?
First a nitpick: your memory card is Memory Stick Pro Duo, it's not an SD card. Secure Digital is one specific type of memory card, distinct from xD, CF, Memory Sticks, and other memory card types.
Okay, not that I've got that off my chest, yes you can import pics to your laptop. Just connect a card reader to the USB port and then put your Memory Stick into the reader. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Card readers should be available at just about any department, electronics, or office-supply store. One important point to remember is to make sure you get a card reader that can read Memory Stick Pro Duos. If you get, for example, an SD card reader, it won't do you any good.
Jun 11, 2012 | Sony Cybershot DSC-T200 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
HOW CAN I REMOVE MEMORY CARD?
Hi There and Welcome to Fixya.
To remove/insert the memory stick pro duo from your Cybershot DSCW55, follow these steps :
  • Open the battery/memory stick duo cover
  • Remove the battery pack
  • Remove/insert the memory stick duo (insert with the terminal facing the camera lens)
  • Insert the battery pack and close the battery/memory stick duo cover
For more helpful information and details regarding usage and maintenance of this camera, please follow the below link :
Sony CyberShot
Pull up the website and simply click the "Instruction Manual".
Enjoy, and Thanks for using Fixya.
Apr 12, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
DSC F707 Error C:13:01
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Aug 10, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony
there might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Sony Cyber-shot DSC-H5 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
