Question about Sylvania 6427FF TV
Digital converter boxes.
We have 2 tvs that run off an arreal that is on our house so i was wondering if one converter box will work to run both tvs or will we have to buy 2. we live in ontasrio canada.
    Champion:
  • 317 Answers
You will need one for each set.
Posted on Aug 03, 2008
SOURCE:
How do ihook up to a second tv from ikonvert digital box
your going to either buy a share, Y-cable to run both tvs, or switch box to select the tv you want to watch a that time
the connector on the tv has to match the connectors on the converter box.
just remember you will be watch same channel at the same time
you could also leave everything hooked up, than get Y-connector and put on the output of the box run line to each tv your still be watching the same channel without doing a lot of work and time
Mar 10, 2015 | Supersonic IKONVERT Digital TV Converter...
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Is this digatil i am trying to buy a converter box i do not have cable
No,all CRT tvs(tube tvs) are analog tvs.Tries those Big Box stores like Walmart,Target might still sell those Digital converter box.Not,tries websites like Amazon.com,Ebay.com to buy the Digital converter box to convert digital signal to ur analog tv.
Nov 10, 2010 | Samsung CXJ1952 19 in. Combo
DO I NEED A DIGITAL CONVERTER TO OPERATE A 4 YEAR OLD JVC MODEL AV-32D305 WITH AN ANTENNA?
If you have cable running to your house, cable still uses RF and older TVs work fine. The problem comes when you try to grab stations from the air. The signal is still UHF, but the information riding on that UHF signal is digital, and will need a converter box to turn it back to analog so your older TV will understand it. . Cable: None needed. . Antenna: Need a box.
Nov 25, 2009 | JVC AV-32D305 32" TV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
My Insignia Converter boxes - 7-19-09
Switch to a powered DTV antenna.
Your analog antenna may be too far out of range to effectively pick up signal.
Thanks for using FixYa!!
Jul 19, 2009 | Insignia Digital-to-Analog Converter for...
Remote doesn't work for the Insignia converter box
Strange as it seems, both converters had "bad" batteries included for the remote. Bought new batteries, problem solved.
Dec 27, 2008 | Insignia Digital-to-Analog Converter for...
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Sylvania 6427FF TV Logo
91 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
