Question about Dishwashers
I rinsed my dishes first, then i put in a tablet to wash the dishes ad never thought any more about it untill the following morning i went to empty the dishes and discovered that the dishes had not been washed and the tablet was still in its compartment, i also noticed that there is dirty water in the bottom of the dishwasher, on the panal there are two lights CHECK WATER, AND THE ACTIVE LIGHT is on, i would be very grateful if you tell me what is the problen. thank you ANNETTE BECK
    President:
  • 778 Answers
Sounds like the drain is clogged, so the dirty water is not draining and the dishwasher won't cycle because if it did it would overflow (causing a mess). So I would suggest trying to remove the obstruction (could be food or a utensil, etc.... at the drain hole or in the hose itself ). I am pretty sure once you clear the blockage that your machine will operate normally again. You may have to unplug it (for a few minutes) after clearing the blockage to let it reset to default.
Posted on Apr 02, 2008
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
Jun 07, 2014 | Hotpoint 24 in. FDW60 Free-standing...
I went to take out my dishes out of the dishwasher this morning and the tablet was sitting at the bottom of the machine half disolved and most of my dishes weren't washed properly. What is the problem?
1. Check that water enters dishwasher.
2. Check that water is heated,tablet door will then open, this allows the propellor to shoot hot water at tablet to dissolve.
Apr 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
White film left on the dishes after going through the dishwasher. Why?
Too much rinse agent. If you are using powder or gel, set pointer knob on rinse agent dispenser to a lower setting. If you were using the tablets, they have rinse agent built into them, and the additional rinse agent from the dispenser equals a double dose, so the film shows up. Stop using tablets until liquid rinse agent dispenser is empty.
Apr 14, 2011 | GE Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Dishes not clean, water spots
You might have really really hard water which would leave mineral deposits on your dishes,,, something could also be blocking the wash arm from rotating, or the water from shooting out of the wash arm which would result in very poor cleaning results
Mar 12, 2009 | Dishwashers
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes are wet and the not drying
Try using just the rinse aid in the tablets, don't put anymore rinse aid in the dispenser(This may take a while for it to empty) this should help with the drying.
failing that look at manual that will tell you how to put the extra heat programme on
Deep Diver
Dec 22, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
156 people viewed this question
Top Dishwashers Experts
Owen Barnes
