Question about Canon L120 Fax Laser Printer
Check scan platform
Hi, Can receive faxes but not send.
Get the prompt "check scan platform", any idea what the solution is?
Thanks
  • 1 more comment
  • Anonymous Mar 26, 2009
    the fax it saying check the scan platform
  • ntobeko zikhali Mar 26, 2009
    check scan platform
  • Anonymous Apr 10, 2009
    I have the same problem, the Fax Machine displays- CHECK SCAN PLATFORM" I looked in the manual at the given page, as you said, but I didn'd find neither this malfunction, nor its solution... :(
  • 398 Answers
Two things cause this, a dirty scanner or after the user cleaned the scanner it was reassembled incorrectly Directions are in chapter 8-4 of the “Basic Guide”
Posted on May 30, 2008
The manual we have only goes up to 5-8 so we can't resolve the problem
Posted on Jul 03, 2008
Canon L120 - What does this error message mean?
Check Scan Platform, means:
The scanning platform is dirty, or not set into scanning position.
Solution
Clean the scanning area, or lift the scanning platform into place.
Nov 26, 2011 | Canon L120 Fax Laser Printer
I work IT Support. I have a user that cant send/receive fax from xerox phaser 3300 mfp. They can scan/print fine. Thoughts?
check the fax line. Plug that line into the regular fax machine to see if you can receive/send from there. What where you should start. Thanks
Apr 12, 2011 | Computers & Internet
Check scan platform
Above paper cover, there is scann platform. Put it back in up possition.
Jun 11, 2010 | Canon FAX L-120 Plain Paper Laser
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon Fax-L120/L100
Check the manual for how to clean the scan platform (glass).
Jul 02, 2008 | Canon L120 Fax Laser Printer
Check Scan Platform
Once run the fax setup wizard from the HP Director and then try to send the fax again.
Apr 24, 2008 | HP Officejet 4355 All-In-One InkJet...
Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Mar 03, 2008 | Canon FAX-B160 Plain Paper Bubblejet
Coulnd't send a fax
I had the same problem and called canon helpline.
They said to unplug the machine from the mains, then take out the plastic guard where the paper tray is fitted. There is a lever just above the paper tray. Make sure that it is pressed up completely. Then reconnect to mains.
I tried it and it worked.
Dec 27, 2007 | Canon FAX-L1000 Plain Paper Laser
Caution check scan platform
you need to check the scanning platform that is above the paper tray. it may be loose. you will have to close it properly and hopefully it will start working.
regards,
kumar
Oct 15, 2007 | Canon FAX L-120 Plain Paper Laser
Canon L120 Fax Laser Printer Logo
539 people viewed this question
old marine
old marine
