Question about SimpleTech 500GB SIMPLEDRIVE EXT HD-USB 2.0 7200 PININFARINA 500 GB Hard Drive
2nd partition disk drive D: is not accessible
Hey buddy . , pls help me
i had 2 partition on one disk drive C and D. Now i opened that drive there was an error "D:\ is not accessible". but i run by path such as D:\mymusic\BreakingBenjamin that's ok.. so why? pls help me..
thanks
  • 106 Answers
Its a virus effect...try right click on the D: and then open with internet Explorer and scan the drive for virus effect
Posted on Apr 05, 2008
    Scholar:
  • 38 Answers
Several brands now have the recovery software and backup of your computer on the D: partition.
You probably have XP (Vista doesn't try to stop you from viewing the contents of the drive). I would recommend using a 3rd party explorer clone to move the music files back to the C: and leave that partition alone. Also if you have not made your recovery discs yet do so before messing with the recovery partition.
On an HP or Compaq the recovery disc manager can be found under HP or under PC Help & Tools in the start menu.
SOURCE:
Pls help me to partition my hard disk drive as c and D
If the computer is already running with Windows, then you can use a program called Partition magic to partition the C drive into two partitions - a C and a D drive.
If you are installing Windows from scratch then you can use the Windows installation CD to install Windows. When the Windows installation begins, delete the existing partition, then create a new partition but size the 1st partition (C drive) to what you require and continue with the installation.
When Windows has finished installing you can create the D drive by opening Control Panel - Administrative Tools - Computer Management - Disk Management - click on the un-partitioned portion of the hard disk, create a extended partition - and then format this partition in NTSF When completed Disk 1 will be shown as Healthy (system)
Mar 20, 2011 | Computers & Internet
Pls i need help.. i have a western digital external 320gb sata 2.5" hdd, i connect it to my pc via usb. I split it into two partitions one as Fat32 and the other as NTFS, which has been running very...
When you power up the computer press F8 key then enter in safe mode. Then open my computer if you are able to see all partition then take backup of all data. If you are not able to access ntfs then right click on my computer icon click on manager then go to disk management and select your removable drive then right click on ntfs partition and tack bakup of all data then format it . then you can use it again. Also make sure on harddisk for jumper settings. Let me know if you need further assistance. thanks for using FixYa.
Dec 07, 2010 | Computers & Internet
I have lg 6300 cdma handset I can access all web site in my handset but google site I can't open. So pls help me
hey buddy please let me know how u abl to access other websites which settings u used
Jul 09, 2010 | Cell Phones
I WANT TO INSTALL LOCAL DISK D ON MY COMPUTOR?
i lose my local disc d in my komputer,my dvd rom can read a disc.how can i instal
Sep 16, 2009 | Dell Dimension 4600 PC Desktop
I cant access the d partition on my hard drive
Hi...
Do you want to access the drive d and get your files. You can not access it when you double click the drive. The drive will says access denied. To access the drive d open My Computer you can see there a address, there is and arrow there just click. Chose the drive d to open i am sure that you can open it.
Regards
PCmania
Aug 27, 2009 | Computers & Internet
Well this is kinda of a funky setup you got going with 3 drives, why dont you make a partition on the c drive to handle vista and make another partition on C: to handle xp? Run a multiboot and there you go. See vista is going to take over that secound drive no matter what, also you got to realize that its hard stating a multiboot from two diffrent drives, use your other 2 drives to store your programs and your set.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 05, 2009 | Microsoft Windows XP Professional SP3 Full...
2nd HDD
Check Computer Management / Disk Management. Windows on Windows XP, Probably the Drive needs formatting first and partitioning before it will visible on My Computer. By Default the new Hard Drive is "Unpartitioned / Unallocated". So acess disk Management to format and partition the Hard Drive.
To access the computer management and disk management and create and partition under disk management, Check Videos for guide :
Nov 10, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Kingston pend drive cant open
If you are using Sandisk USB Drives, it may be that partition is password protected. If you can run the U3 Launchpad, it should prompt you for a password for you to access your "Drive F". Put in your password, and Drive F should be accessible.
Oct 29, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Using as startup disk
If you used Acronis, you need to clone the 30Gb and not backup. In doing so, the booting information is likewise copied to the 80Gb, whereas back up is simply copying contents (that you specified) hence will not boot and not be active.
Pls remember that by cloning, Acronis would erase the partition (and contents) of the 80Gb. At certain settings, it would also split the 80Gb into 2 partitions; 30Gb & 50Gb. Further, verify that the 80Gb is "Set Active" and partitioned as a Primary and not Logical.
As to your other concern of installing, in some instances, some not so recent motherboards' BIOS/CMOS will not recognize the 80Gb. Other than that, you were doing it correct; new 80Gb as primary/master with jumper to the pins nearest the IDE cable, any other device (CD ROM or another HD) should be set as primary/slave (SL). Additionally, pls verify that your motherboard auto-detected your new 80Gb as your primary boot media (settings in your CMOS/BIOS).
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 03, 2007 | Samsung (SP0822N) 80 GB Hard Drive
SimpleTech 500GB SIMPLEDRIVE EXT HD-USB 2.0 7200 PININFARINA 500 GB Hard Drive Logo
103 people viewed this question
Top SimpleTech Computers & Internet Experts
Ekse
GFXTech
Marvin
Marvin
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
