TV input from dvd player.
The video input (yellow) socket on my tv is faulty and when I connect my dvd player the picture is distorted and th ecolour flashes on and off. I have changed the cable and it does the same thing.
I have connect a phillips dvd hard drive to my plasma by the componet cables and i get the sound but no picture can anyone tell what i am doing wrong
Posted on Jun 08, 2008
I have no sound at all on my Magnavox MDV460/17 DVD player. I know the TV sound works. Picture works on DVD player, but no sound.
Hi,Would you pls check the connection that you have made between TV and DVD player..?
2xRCA (white+Red) will go to Audio IN sockets of TV in addition to 1xRCA Yellow video cable goes to "Video IN socket of TV..
if the connections are right than you must select the right source on TV ,as AV1 ,AV2 which corresponds to the cable input sockets of your TV.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
Since disconnecting my Sony DVD player it now only plays in black and white. It is relatively old model DVP-NS51P. I have successfully connected an alternative DVD player to the same TV so it cannot be a...
Make sure that the TV system that the DVD is outputting is NTSC, Press SYSTEM button on the remote control (is there's such button) or change the system in the DVD's menu.
Nov 09, 2010 | Sony DVP-NS51P DVD Player
I was given a GE 27GT616 television but can't figure out how to connect a converter box or dvd player
If your tv has video in socket (yellow color)and audio in socket(white color),you will connect the dvd player audio video output. it will give give clarity picture. your tv have not av socketyou can connect your dvd player audio video output to converter audio video input.And then connect to converter RFout to tv Rf input(antenna socket)and tune the tv you wlii get picture.
Jul 31, 2010 | GE 27GT616 27" TV
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
How to connect (yellow, red & white) to component video
Connect either DVD player or DTH with the TV. There is only one input on your TV.
May 27, 2017 | Akai DVD-3850S DVD Player
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
Video Input
Are you sure that the source is generating a video signal? It is extremely rare for both front and rear Video Input sockets to fail simultaneoisly. from your description, i would suspect the cable connecting the Viseo out of your DVD player / Video Game than the Video Input ports of the TV. If you have another cable, just try again with that. Or, try using the Red to red cable into the Yellow port, using one end at the DVD player and the other at the TV Video Input. If there is image, then it is confirmed that the cable is faulty, and you can get a replacement cable for a few bucks at any Video store.
Mar 20, 2007 | Symphonic ST419E TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
