Question about Car Audio & Video
Everytime i turn my car off and take the key out of the ignition all my stereo presets reset. all connections made are correct, however there is one wire which is left over. it is orange with white stripes and the brouchure says its the car lighting control wire. its a jvc kd-g646 head unit. everything else is working correctly.
  • lhencz Apr 04, 2008
    thanks mate! your suggestion lead me to look at the circuit diagram. all the problem was was the unswitched active and the active running through the ignition were swapped over. works perfectly. thanks!
    Sergeant:
  • 300 Answers
Most stereos have two power connections. One is "constant" (aka always connected to +12V) and the other is switched on/off by the ignition. They may go be various names. The idea is that the constant +12V keeps the stereo from losing all of the settings while the switched power turns the stereo off when the key is not on "start" or "accessory". It sounds like the both connections may be made to the switched power on your car, causing it to go completely powerless when your car is off.
Are the presets reset after you turn the car off or only after you turn your car back on? If they only reset after turning the car back on, it's possible the battery and/or electrical system is having trouble keeping the system voltage up while the starter is trying to turn the engine.
The illumination signal is usually used to let the stereo know when you've turned your headlights on, so it can dim the display automatically. Should be completely separate from your issue.
Posted on Apr 02, 2008
SOURCE:
Head unit not getting the right constant power
normally when an aftermarket stereo is installed the yellow wire is for constant power gets connected with the ignition power wire and what you said is what happens in result. get a multimeter, set it onto dc volts and put the black lead onto something metal and then id use the red lead to test wires for a constant 12volts when key is in the off position. Once a wire is found connect it to the yellow wire of the stereo
Feb 19, 2013 | 1999 Acura Integra
Replaced stereo and loses presets???
Hi Welsh, It sound to me as if the constant live feed has not been connected or that the cables have been incorrectly connected. The set is fed with a constantly live connection which is live even when the ignition is off, thereby giving power to the memory circuit. I believe either that has been swapped with the ignition power on, or not fitted at all. Regards John
Mar 31, 2012 | Cars & Trucks
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Automatically goes to the demo mode on start-up
to turn off demo mode put radio into stand by were it is running demo mode and hold number 6 till it switches off. As for the key problem its the key that is making the key live connection on your model of car so this can not be changed. sorry
Apr 29, 2009 | Car Audio & Video
DehP6700 mp restet everytime keys is turned on.
first red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Nov 13, 2008 | Car Audio & Video
When my daughter turns her car audio off, we loose preset stations.
Two questions to narrow this down - one, is it an aftermarket stereo, or a factory one? Two, with the key out of the car, can the stereo be turned on?
If it's aftermarket and it powers on when the key is off, then it's likely two wires are reversed in the harness behind the deck - the constant 12v wire and the switched 12v wire. The constant one is the yellow one, which always supplies power to the deck, keeping power there for the preset memory and the tone settings. The ignition-switched one is so that when the key is turned off, the stereo shuts off (this is the red wire on the harness). If these were reversed, the stereo would always be able to be turned on, and power to the memory settings would be lost when the key is turned off.
Sep 10, 2008 | Car Audio & Video
Car CD stereo
Either you blew the memory fuse or didn't connect the radio to the proper wire. Check fuses inside and under the hood.
The memory wire to the radio needs 12v all the time. If it's not connected or no power at the lead the radio will reset every time you turn off the car.
Jul 08, 2008 | Car Audio & Video
Not powering up
do you loose your presets everytime?
Dec 15, 2007 | Alpine IVA-D310 Car DVD Player
Car Audio & Video Logo
336 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
