Question about Sony Cyber-Shot DSC-P32 Digital Camera
My g&e 8.0 megapixel camera won't work!!!!i need help
Well my lil nephew dropped my camera!!it still works but my lens won't come out it just says lens error!!plz!!help me!!
  • 104 Answers
Ya,this is lens unit dislocated or gears problum repairable
Posted on Apr 02, 2008
SOURCE:
Sanyo VPC-S1415 lens stuck in camera
that's happen due to physical damage like dropping etc.
try to open inside and align well the lens mechanism
Jul 01, 2016 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
I dropped my canon and the lens touchd the ground and it stopped functioning
Depending on damage that might have been done when you dropped it, you might try this:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem might be easy to fix. VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Now power on the camera and see if it works. If not, you might have to send it in for repairs.
Jan 13, 2014 | Canon PowerShot A2300 16 Megapixel Digital...
My lens won't open
The gear linkage in the lens is seized or is out of alignment, this is a job for a camera specialist, I recommend estimate first.
Jun 23, 2012 | Canon Sx150is Powershot Sx150 Is 5664b001...
I dropped the camera and the zoom lens got off line. It won't close or go back in the camera. It looks stuck and I tried pushing it in but I'm afraid that I might push hard that it'll break...
The lens may be fixable but most likely will need to be replaced.
If the lens is stuck straight or won't come out at all it needs to be replaced.
If the lens is stuck at an angle then you may be able to snap it back to the center by pressing the edge of the lens back towards center while holding on the outer ring of the lens.
Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
I bought an 18 megapixel d60, is there a new 20 megapixel d60 in the market,,if there is, do i need to buy a newer d60 just to increase its megapixel
There would be almost no noticeable difference between an 18 megapixel camera and a 20 megapixel camera. Personally, I would look for a camera with a fast shutter speed and a high Optical Zoom.
The Canon EOS D60 is a discontinued 6.3 megapixel digital single lens reflex (DSLR) camera.
The Canon EOS 40D is a 10.1 megapixel digital single lens reflex camera.
The Canon EOS 1D Mark III is a 21.1 megapixel digital single lens reflex camera, and is the first to break the 20 megapixel barrier.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 14, 2011 | Cameras
When I switch it on it says lens error 0x0311 The camera is pentax. Optio E70L 10.1 megapixel
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 21, 2011 | Pentax Optio E60 Digital Camera
Olympus Stylus 600/Digital 600 6.0 megapixel
Hi
This camera can be very picky when it comes to the front lens cover... It's not a simple mechanism and has many small parts and gears involved. If the lens cover is dislodged it won't work smoothly, and if the case is dented it will not be able to move properly and this can cause lens problems.
If the lens was out when the camera was dropped, then it's possible the lens was damaged and not the lens cover. Sometimes you can tear down the lens, clean it and rebuild it and it will work smoothly again, sometimes this doesn't work and the lens needs to be replaced.
If you're comfortable opening the camera, first check out the lens with the front body section removed so nothing is blocking the lens cover. Does it work properly now? If not, then expect lens damage to be the issue.
We are an AFFORDABLE digital camera repair shop... if we can assist you with parts or do the repair please let us know. (google: darntoothysam)
Hopefully this is of some help. Even if you don't use our services please feel free to let me know if you need more assistance.
Good luck from Darntoothysam com
Thomas
Oct 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Help
this the lens unit stucked or dislocation u contact ur local repairer repairable
Mar 30, 2008 | Canon PowerShot SD600 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
