Question about Motorola Mobility C261 Cellular Phone
Change date & time
I need to change the date & time settings. Please assist.
    Novelist:
  • 119 Answers
Dear Kazme,
Please find the user manual of you phone below. (2.61mb download)
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=eae22c1cef62d010VgnVCM1000008206b00aRCRD&show=productHome
At page 26 you will find the info you requested. If for any reason you cannot proceed to the Moto webpage see the instructions below.
To set the time and date for your phone:
Find it: Press M > Settings > Initial Setup
> Time and Date
Note: To choose an analog or digital clock for
your home screen, press M > Personalize
> Home Screen > Clock Set.
Regards
Please Rate this Solution!! Thanks!
Posted on Apr 02, 2008
SOURCE:
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
My e 63 isnt supporting themes which are being downloaded from the following web sites example zedge and symbian web site
Don't worry this is simple settings issue.
Note:Please download only E63 series Themes only.......not other phone themes...
To solve this problem follow the steps:
1)Go to Menu-> Tools-> Application Manager
2) Then press (options) button, select (settings)
3) Make sure <Software installation > is set to "All" and < Online certif.check > is set to "Off"
Some time you get certificate expire to solve this you have to change the date.This is to prevent the users from using expired application:
If you encounter Expired Certificate error during installation, please set your phone date to 03/03/2007 before installion of the theme .You can reset your phone date back after installation.
If still the problem persist Change the PC date also because it will get synchronized with your mobile and try different dates so that it will match the application date.(Reason is every application is valid for a period of time
example.from 03/03/2007 to 03/09/2007 so you have to give date between this.So try old dates usually some years back...
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 31, 2010 | Nokia E63 Cell Phone
I have a AT2 Plus machine and cannot find my manual. the time and date is set incorrectly and I would like to change that. could you please assist me.
To change the Time :
- Firstly, press the following key sequence : ALT, 9, 1, 1
- Then, enter the time (HHMMSS)
- Finally you'll hear the confirmation beep
To change the Date :
- Firstly, press the following key sequence : ALT, 9, 2, 2
- Then, enter the date (DDMMYY)
- Finally, you'll hear the confirmation beep
Jul 02, 2010 | Schiller Cardiovit At 2 Light Ecg Machine
How do I reset time & date?
goto settings and change the date and time...if u mention ur mob brand...i will tell to u bit more.
clear
Apr 29, 2009 | Lands Phones
Changing to correct date on camcorder
To change / reset date and time touch on lcd screen, HOME > SETTINGS > CLOCK / LANG > CLOCK SET and set the date and time.
Above said is mentioned in user manual of DCR-SR42 and you can download it from Sony Support.
Dec 03, 2008 | Sony Handycam DCR-SR42 Camcorder
Setting Time & Date
press and hold the menu/disp for or longer until the hq flashes. press the minus button until the time flashes...then press play button. press +/- until the hour is set, then press the ff button and change the minutes, then ff to the date and change accordingly. When finished press play then stop.
Sep 04, 2008 | Olympus VN-2100PC Digital Voice Recorder
Time/date in the message center
it's in the menu/settings/
do you have a manual on this printer?
also, see this for more assistance
Apr 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Changing Time
Hey peoples this worked for me :)
On the main phone
- hit the "PROGRAM" key
- then key in **
- it asks for a password key in 1234
- then key "NEXT"
- then key "ENTER" (this is to set the date)
- then key "NEXT" (this is too set the time)
- once the time is correct hit the "ENTER" key at the bottom of the phone.
Mar 09, 2008 | Panasonic KX-T7630 Corded Phone
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Motorola Mobility C261 Cellular Phone Logo
197 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
