Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
D-link di-604 can you help me on setting up my d-link di-604 router to use static ip on the type of internet connection instead of using PPPOE, because my isp has given me a static ip address, subnet, gateway, dns 1&2,..i want to know if..after i hav supplied those infos. on the setup page, should i configure the TCP/IP properties..on "obtain ip address automatically" or should i assign them an ip address" i got 3 computers. that will be sharing this connection. i realy need this..to work a.s.a.p. thanks in advance.. aya
I have no success disabling the DHCP server. For me at lease, this will not work
Posted on Apr 24, 2008
Won't dhcp connect with router
the Di-604 is the router. it will provide DHCP if the DHCP function is turned on. IT will not get its own IP from another dhcp router though. At least I have never gotten any to. I set the router IP address manually and then I set the DHCP range to be something that wont interfere with any other static IP addresses.
For instance. I set the router to 192.168.1.5 instead of its default of 192.168.1.1. Then I set the range of DHCP to 192.168.1.150 to 192.168.1.170
You have to log into the router to do these changes. Your manual will tell you how to do this and what the default IP address is that you will need to type into your browser.
Mar 09, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
We are connected to the internet by a satelitte dish. The modem works fine when connected to the desktop computer but when I try to run it through the router I can not connect to the internet. Is there a...
hello! i will be more than glad to assist u in this concern..the possible solution here is u need to setup the internet connection setup on the router.. there are many option like, dynamic setup-this is auto detect, static ip or pppoe, check the type of setup from ur isp.. ex. ur setup is static ip addressing, to check the settings, connect ur computer directly to the modem and from the computer click on start, run and type in cmd,dos prompt will appear, type in at the prompt, ipconfig/all and write down from a piece of paper..the ip address, subnetmask, default gateway , dns server, then u need to type in the info at the setup page of the router on the internet connection setup and selct static ip, if u are using a pppoe, u need to setup the username and password given to u by the isp and set it up to the router and make sure that ur going to disable the pppoe software u used from ur computer.. if u are using a cable modem u need to mac clone the nic of ur computer.. i hope this will help u.. good luck
Aug 03, 2009 | D-Link DIR-615 Wireless Router
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-link DI-604
I didn't quite understand what you meant but Ill explain some stuff you to that might help.
From what I understand you have a dial up router/modem, which is external (outside of your computer/seperate), and you hookup your phone line to it, which then connects into your DI-604 WAN port.
WAN Static IP settings are related to the settings given by the ISP that stay constant. There are 2 types of IP, static and dynamic. I think dial up is dynamic, since you have to connect/disconnect through the phone when you want to get on, this causes the ip to change at each reconnect, unless your ISP treats it differently.
I have no idea what you want to get out of the WAN static IP settings, but this should be handled by the dialup router/modem it self, and generally you dont have to manually enter the static ip, unless the ISP requires it, in that case you would enter this stuff there. The ISP Gateway Address refers to the ISP's router address/modem, I think, since I never heard the term before.
After "My problem:", I didn't understand your problem and can't give you further info until you clarify. Also if you internet is fully connected and working, and you still have problems then you could try resetting the router, by holding the reset button for 10 seconds. This will erase all settings. If that doesn't help try unplugging the router, then holding the reset button for 5-10 seconds, then plugging it in at the same time, then it should be fully reset, unless I forgot how it was supposed to be reset. ( I used to have the same router)
Feb 27, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Internet problem connection.....
your computer has been set up to be the PPPoE account holder for the modem. if you have a router, you will need to configure the router to login to the ISP account using the PPPoE information so that your router is the account holder for the modem, then you will be able attach multiple computers to the internet using the router.
Jun 21, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-LINK DI-604 STATIC IP
Log into the router and go to the configuration page for your WAN port. Change the connection type to static ip.
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
Get router started
Have you tried entering your username and password for your isp provider? You have to enter the config page of your router and enter this information there.
Jan 31, 2008 | Computers & Internet
D Link 604 will not connect to internet
Hi Goldy,
The 604 should setup easily. Make sure you have it set to automatically get IP if you are using Cable, and for PPPOE if you are using DSL.
Once you have it setup. Shut down everything. Plug in the modem, wait 2 min. This allows the modem to get the info it needs from your ISP. Then bootup the 604. Wait 2 min, for it to get the info it needs from the modem, then boot up your computers.
Got to start>run and type in CMD. In the black box that opens, type in IPCONFIG. Your IP listed should be 192.168.x.x. THe X's can be any number from 1 to 253. If the IP is 169.xxx.x.x, you are not getting data from the 604. Check your firewalls, expecially if you are using a third party one, like Norton.
Jan 06, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
249 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
