Won't turn on. Plug is fine. Remote is fine. No standby light. No click when remote ON is pressed. Set is 7 yrs old, never been moved, no other problems ever.
  • Anonymous Dec 28, 2008
    Hi
    Yep, have a NEC FS6390 TV.
    No Power up fault.
    Have found dry joints on circuit board, mainly in the power supply region and some burnt components also in the Power Supply section of PCB.
    Having problems finding a schematic??? Also can you recommend other parts that may or should be replaced?.
    Thanking You
  • 927 Answers
If you are sure that the a/c outlet is good, try another. No lights, no clicks your main fuse in your unit may be open. CAUTION: if you replace main fuse with same value & it opens again. STOP and call a servicer. You might have shorted electronic devises in the main a/c circuits. Always call a service company that is factory authorised to service your product. Good luck.
Posted on Apr 02, 2008
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Wont power on
    some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
    Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
    My LG TV red light won't turn on. although the plug fuse and the remote OK
    Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
    May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
    I have a Pioneer PDP-5030HD plasma and the plasma display does not turn on. The standby/on power indicator light on plasma display is blinking red (after turning it on with my remote, it turns green for a...
    First check batteries in the remote are charged.Try pushing one of the channel selection numbers on the remote as it may be the off/on on your remote is stuck or has died completely. if this does not fix the problem try unplugging the set from the wall wait 5 mins (approx) and re plug into wall socket and try turning on .
    Oct 25, 2017 | Pioneer PureVision PDP-5030HD 50 in....
    TV suddenly stopped working - won't switch on from top - won't respond to remote - no standby light - fuse is fine - set is 3 yrs old
    The Power Supply is probably causing the problem if you are not getting any response or LED flash or Stand by
    Jul 03, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    I want to find the Sky remote code for this Tv.
    Just got an LG 42LH2000 and code 0206 works
    May 16, 2009 | LG Televison & Video
    Child lock will not allow my tv to turn on
    i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
    Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
    Unlocking my DVD Player
    Try this,it should work....Rod
    To change the current region setting on this player
    1. Press the Standby button on your remote control to place the unit into Standby
    2. Press the Standby button on your remote control to turn on the unit
    3. Press the Open/Close button on your remote control to open the drive tray
    4. Press the Clear button on your remote control
    5. Press the 1 button on your remote control
    6. Press the 3 button on your remote control
    7. Press the 6 button on your remote control
    8. Press the 9 button on your remote control
    9. Press the 0 button on your remote control
    10. Press the Open/Close button on your remote control to close the drive tray
    11. Press the Standby button on your remote control to place the unit into Standby
    12. Press the Standby button on your remote control to turn on the unit
    Jul 16, 2008 | Durabrand Televison & Video
    Tv stuck in standby
    If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
    Sep 10, 2006 | Sony KV-32S42 32" TV
    XV-N322 - Lock will not unlock
    My problem was fixed by...having the DVD powered off, holding down the stop button on the player and hitting the power button on the remote.
    Good luck!!
    Jan 22, 2006 | JVC XV-N320 DVD Player
    Televison & Video Logo
    46 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
