Question about Olympus Stylus 770 SW Digital Camera
Olympus Underwater MJU 795 LEAKS
I have had my so called underwater camera for a month. I used it in the water a few times. After about the 5th time in the water it leaked through the battery. Of course this ruins the camera. Took it back for warranty repair and low and behold Olympus is not so willing to stand by their warranty. So for double the price of the camera they were willing to fix it.
  • 5 more comments
  • Anonymous Jul 12, 2008
    I have only used the camera in 4 water situations, once in the pool as a test, and a few times down the Green River. I regularly let it dry once it has been in a wet situation, yet it still gets water on the inside of the lens and the screen. Very disappointing.
  • Anonymous Feb 27, 2009
    I had the 795sw and it also leaked. It is out of warranty of course. I dont think Ill be buying another one.
  • Anonymous Mar 06, 2009
    I had the same problem, got it fixed, just to leak again! How disappointing!!! Should have gotten a regular camera, at least the pic quality would be good!
  • Anonymous Mar 10, 2009
    leaked once. got it fixed. leaked again!
  • Anonymous Apr 09, 2009
    Just bought it a month ago. Leaks while I was snorkelling. Dun buy this camera
  • Anonymous May 01, 2009
    Olynpus 770 SW 18 months old has blur spot on all images top left corner.
    Started this after a snorkling event.
    Can only assume water made it's way into the camera.
    Any suggestions on how to repair or, know of a source for breakdown illustrations?
  • Anonymous May 13, 2009
    Why advertise waterproofness and even have multiple underwater picture options when the camera just can't withstand it? Same deal. Bought the camera for minor underwater use and because I manage to beat things to death. The camera works but no more image on the LCD. Image quality has always been terrible. Do not buy this camera.
I have an olympus 770 sw I used to have the same problem... the solution is after using your camera make sure the camera is dry and open the slot for the battery and clean it and do the same for the other slot somtimes youll get small debree in the cracks of your cameras cover for the battery slot thats were the water enters. I use a little bit of vaseline on the rubber pading for the battery cover to lube it out and had no problems sinse.
Posted on Jul 05, 2009
As all humans should know this as a fact, nothing made to day is 100 percent waterproof. dont mind what the data says, water will find its way anywhere and everywhere. as a matter of speaking, the only thing that you have is water proof, is your self.
Posted on May 25, 2008
SOURCE:
My Olympus Stylus Tough -6000 lost its underwater capability. it gets wet no matter how much i make sure the battery and USB gaskets/seal clean. can it still bi fixed? how?
I wish there was a way I could shout this to everyone so they would all know it at once....ALL SO-CALLED "WATERPROOF" POINT AND SHOOT CAMERAS WILL EVENTUALLY LEAK. THIS WILL USUALLY HAPPEN AFTER YOU HAVE TAKEN THOSE "ONCE IN A LIFETIME" PICTURES. The only real underwater cameras are in a special underwater housing.
Apr 08, 2011 | Olympus Cameras
I've had this camera for over a year, an lately when i take into the water the screen will turn black, it will turn on and take one or two pictures but i cannot see them. Today however it did that, but...
Are you taking it more than 10 feet underwater? It is only waterproof up to 10 feet underwater. It is also possible that there is a crack or hole somewhere in the case; a hairline crack could leak water in there. Let it sit a day without the battery and try again. If it still won't turn on, then it's probably shot. If it is still under warranty, Olympus will probably repair or replace it for you. If not, considering that it is probably beyond repair, I would seek out a replacement unit.
Jul 01, 2010 | Olympus Stylus 850SW Digital Camera
Fuji's waterproof camera not waterproof, and they say that we must have opened the battery door while under water. They want $110 to fix the camera!!! The battery door leaks and they won't admit there is a...
It's a gray area, your word against theirs. Unless you can find 100 people who have had the same problem, you have little chance of making a successful claim. Hopefully, the time will soon come when induction charging and Bluetooth will make it possible to build completely sealed underwater cameras.
Jan 27, 2018 | Fuji Cameras
When i turn the camera on it chimes 3 times then shuts off
you should have dropped the camrer down at least once. you have to replace the lens array.it costs around 60$.
Jun 04, 2009 | Olympus ? 1030SW Digital Camera
Blurry lens after using it underwater
Sadly that symptom indicates that the camera is broken.
The device's seal protects both from the condition that you are seeing, but also protects the internal circuits from moisture.
If water has gotten inside the camera, I would pursue returning it and getting a replacement from the company.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 29, 2009 | Olympus Stylus 850SW Digital Camera
Not so waterproof?
Since the camera is billed as waterproof I would send it to an Olympus service center for an evaluation to see if it going to be covered under warranty for repair if I were you. The repair techs will evaluate the camera and let you know if it is indeed repairable.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $107.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 12, 2009 | Olympus Stylus 710 Digital Camera
Water in camera
It depends how much salt water leaked in really. If it was only a small amount, you may be lucky but the fact is, salt water corrodes extremely fast. The sooner you have your camera looked at the better. If you can see liquid in the lens or viewfinder I would say thats extreme and probably not worth fixing. Good luck!
Apr 07, 2009 | Canon PowerShot S1 IS Digital Camera
Water
the same thing happened to me and olympus repaired it for free. it is a manufacturing mistake. call or email the company and they'll help you get it fixed. ~~Shelly
Jun 26, 2007 | Olympus Stylus 720 SW Digital Camera
Olympus Stylus 770 SW Digital Camera Logo
679 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
