Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
Lab manual 1. To detect the sensor scanning system to overcome limitation of fixed sensors on various robotic applications, ultrasonic sensor, laser range finders, infrared detectors and miniature. 2. To find the horizontal and vertical movement up to 180o in either direction. 3. To detect objects with infrared ray detector. 4. To determine object distance (3cm ? 300cm). 5. To detect distance (10cm to 80 cm) with infrared object detector. 6. To determine 5 Axis Robotic Arm movement and its degree of rotation. 7. To lift the object and place 100m away in various directions. 8. To find the gripper movement ( 0 to 50mm). 9. To study various Robotic Arm Configurations. 10. To study Pick and Place Robot
Have a Ford fusion 06 Have p0141 code I fix the oxygen sensor but the codes still comes on?
Did you replace the right one ? This code does not necessarily mean the O2 sensor is bad . The code description say O2 heater " CIRCUIT " bank 1 sensor 2 Did you check the wiring , the fuse ?
P0141 - O2 Heater Circuit (Bank 1, Sensor 2) Description: See the description for DTC P0135. Possible Causes: See the possible causes for DTC P0135. Diagnostic Aids: See the diagnostic aids for DTC P0135. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test DW . P0135 - O2 Heater Circuit (Bank 1, Sensor 1) Description: During testing the heated oxygen sensor (HO2S) heaters are checked for open and short circuits and excessive current draw. The test fails when the current draw exceeds a calibrated limit or an open or short circuit is detected. Possible Causes:
  • Vacuum hose disconnected on exhaust gas recirculation (EGR) system module (ESM) applications
  • Short to VPWR in the harness or HO2S
  • Water in the harness connector
  • Open VPWR circuit
  • Open GND circuit
  • Low battery voltage
  • Corrosion or incorrect harness connections
  • Damaged HO2S heater
Diagnostic Aids: Check the HO2S electrical connector for damage, corrosion, and water intrusion.
Damaged HO2S heater. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test DW .
Mar 31, 2015 | 2006 Ford Fusion
Tip
ERROR codes Canon 4050
Canon 4050 E000 No fuser heat E001 High fuser temperature or shorter thermistor E002 Low temperature or bad thermistor E003 Fuser problem E004 Bad SSR (heat staying on) E010 Drive E020 Black toner motor E030 Counter E080 Interface problem with color unit E081 Vertical drive motor E082 Horizontal drive motor E083 Color unit sensor on right E084 Color unit sensor on left E085 Color unit release sensor or release or solonoid E086 Color unit claw release E089 Laser problem E100 Laser problem E110 Laser motor E140 Laser E202 Scan E203 Scan E204 Scan E210 Lens E223 Color unit filter drive motor E240 DC controller E401 RDF pickup motor E402 RDF belt motor E403 RDF feed motor E411 RDF document sensor E500 Sorter-Copier communication error E510 Sorter drive E512 Sorter driveE513 Sorter drive E514 Sorter drive E520 Top limit sensor or stack sensor E530 Sorter home sensor E531 Stapler home sensor E535 Stapler swing sensor E540 Stack shift sensor E660 IC card E710 DC controller E711 DC controller E714 DC controller E800 Power off circuit
on Jan 18, 2010 | Office Equipment & Supplies
2006 suzuki reno code 2106
read the FSM book yet or alldata.com???????
2106
2L automatic?
says
Trouble Code: P2106 (2.0L L4 VIN - Auto)
Throttle Actuator Control (TAC) System Performance - Throttle Limitation Active
Number of Trips to Set Code: 1
Trouble Code Conditions:
Ignition ON. The ECM detects the system is in Limit Performance Mode.
Possible Causes:
  • Throttle body
this means the ECU is in limphome mode.
and is cause because the ECU sees throttle sensors. that dont JIBE
There are effectively (insane yes) 4 TPS sensors
2 under foot.
2 in TB.
if any disagree at any time BAM, limphome mode sets.
"limited performance, old suz name was FAIL SAFE.
no matter its just the same.
use a REAL scan tool that sees ALL codes, i suspect you missed some, is this an AUTOZONED scan? with cheap, tool?
try an Innova 3160 tool. and see them all.
it is suspisious to me , only ONE DTC error !!!
Jul 12, 2014 | 2003 Suzuki Aerio
Trouble codes p1131, p1151 and p0171 for 2001 expedition
I don't care how handy you are , that's not going to help you unless you have knowledge of OBD 2 engine management system for your vehicle . Plus having diagnostic test equipment , scan tool to view engine sensor data ., an knowing how to do automotive electrical circuit testing.
Po171 Could be just an O2 sensor problem ,looking at scan data for bank 1 sensor 1 for proper switching , could be a easy find for a trained Tech . You on the other hand could spend hundreds an still not fix the problem .
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. For lean and rich DTCs:
  • Fuel system
  • Excessive fuel pressure.
  • Leaking/contaminated fuel injectors.
  • Leaking fuel pressure regulator.
  • Low fuel pressure or running out of fuel.
  • Vapor recovery system.
  • Induction system:
    • Air leaks after the MAF.
    • Vacuum Leaks.
    • PCV system.
    • Improperly seated engine oil dipstick.
  • EGR system:
    • Leaking gasket.
    • Stuck EGR valve.
    • Leaking diaphragm or EVR.
  • Base Engine:
    • Oil overfill.
    • Cam timing.
    • Cylinder compression.
    • Exhaust leaks before or near the HO2Ss.
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit.
  • Electrical:
    • Short to VPWR in harness or HO2S
    • Water in harness connector
    • Open/Shorted HO2S circuit
    • Corrosion or poor mating terminals and wiring
    • Damaged HO2S
    • Damaged PCM
  • Fuel System:
  • Induction System:
    • Vacuum Leaks
    • PCV system
  • EGR System:
    • Leaking gasket
    • Stuck EGR valve
  • Base Engine:
    • Oil overfill
    • Cam timing
    • Exhaust leaks before or near the HO2S(s)
A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S. P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
P1151 - Lack of HO2S-21 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130 006 O2 Sensor Signal Analysis
Oct 01, 2017 | 2000 Ford Expedition
Hav nad 2100. I dont understand what the lab in post are for?
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use them UNLESS you have a turntable source.
Feb 23, 2011 | NAD C325BEE Amplifier
E07-59
E7-59 Finisher Upper Limit Sensor 1.
Stack Tray Paper Height detection Sensor, or Paper
Hold Lever detection Sensor is defective, or the
connector is disconnected.
2. Upper Limit detection Sensor is defective.
3. Upper Limit detection Sensor connector is
disconnected.
4. PCB is defective.
there is a sensor that registers the top of the top most sheet on the finisher. it determines where the tray should stop as it is filling up. the sensor does come adrift and needs to be refitted back into its holder. i'm afraid you may have to call a technician.
Apr 15, 2010 | Panasonic DP-C213 Color Copier
Runs Rough, Overheats, Transmission - sometimes auto does not shift correctly - have to use manual
have you changed the spark plugs? also any OBD code after fixing the above?
Jan 15, 2018 | 2001 Volkswagen Passat
I have 3 codes that showed up in the computer of my 1995 Ford Windstar
Here is the first half of the codes look till you find the one you have
111 System PASS.
112 ACT sensor circuit grounded.
113 ACT sensor circuit open.
114 ACT sensor is out of Self-Test.
116 ECT sensor is out of Self-Test.
117 ECT sensor circuit grounded.
118 ECT sensor circuit open.
121 TP sensor is out of Self-Test.
122 TP sensor input is less than Self-Test minimum.
123 TP sensor input is greater than Self-Test maximum.
124 TP sensor input voltage is greater than expected.
125 TP sensor input voltage is less than expected.
128 MAP vacuum hose damaged or disconnected.
129 Insufficient MAF input.
136 HEGO sensor circuit indicates system lean (Right HEGO).
137 HEGO sensor circuit indicates system rich (Right HEGO).
139 No HEGO switching (Front Side).
141 Fuel system indicates lean.
144 No HEGO switching (Left Side).
157 MAF sensor circuit open.
158 MAF sensor shorted to power.
159 MAF sensor is out of Self-Test.
167 Insufficient TP input change.
171 Lack of HEGO switching (Rear Side).
172 HEGO sensor circuit indicates lean. (Rear Side).
173 HEGO sensor circuit indicates rich. (Rear Side).
174 Check for diluted engine oil.
175 Lack of HEGO switching (Front Side).
176 HEGO sensor circuit indicates lean. (Front Side).
177 HEGO sensor circuit indicates rich. (Front Side).
178 Check for diluted engine oil.
179 Fuel system at part throttle lean adaptive limit, system rich (Rear Side).
181 Fuel system at part throttle rich adaptive limit, system lean (Rear Side).
182 Fuel system at idle lean adaptive limit, system rich (Rear Side).
183 Fuel system at idle rich adaptive limit, system lean (Rear Side).
184 MAF sensor input voltage is greater than expected, in range.
185 MAF sensor input voltage is less than expected, in range.
186 Closed loop injector pulse width longer than expected.
187 Closed loop injector pulse width shorter than expected.
188 Fuel system at part throttle lean adaptive limit, system rich (Front Side).
189 Fuel system at part throttle rich adaptive limit, system lean (Front Side).
193 Flexible Fuel sensor circuit failure.
211 PIP circuit failure.
212 Loss of tachometer/IDM input.
213 EEC SPOUT circuit open.
214 CID circuit failure.
215 PCM detected coil 1 primary circuit failure.
216 PCM detected coil 2 primary circuit failure.
217 PCM detected coil 3 primary circuit failure.
218 Loss of ignition diagnostic monitor signal-left side.
219 Spark timing defaulted to 10 degrees, spark output circuit open.
221 Spark timing error.
222 Loss of ignition diagnostic monitor signal-right side.
223 Loss of dual plug inhibit control.
224 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
225 Knock not sensed during dynamic response test KOER.
226 Ignition diagnostic monitor signal not received.
232 PCM detected coil 1, 2, 3 or 4 primary circuit failure.
238 PCM detected coil 4 primary circuit failure.
241 Ignition control module to PCM ignition diagnostic monitor pulse width transmission error.
244 Cylinder Identification circuit fault present when cylinder balance test requested.
311 Secondary air injection system inoperative during KOER self-test (bank #1).
312 Secondary air injection system misdirected during KOER self-test.
313 Secondary air injection system not bypassed during KOER self-test.
314 Secondary air injection system inoperative during KOER self-test (bank #2)
326 PFE sensor circuit voltage lower than expected.
327 PFE sensor circuit voltage below Self-Test minimum.
328 Exhaust gas recirculation valve position sensor closed voltage lower than expected.
332 Insufficient EGR flow.
334 Exhaust gas recirculation valve position sensor closed voltage higher than expected.
335 PFE sensor circuit voltage out of Self-Test range.
336 PFE sensor circuit voltage higher than expected.
337 PFE sensor circuit voltage above Self-Test maximum.
338 Engine coolant temperature lower than expected (thermostat test).
339 Engine coolant temperature higher than expected (thermostat test).
341 Octane adjust service pin open.
381 Frequent A/C clutch cycling.
411 Cannot control RPM during KOER low RPM check.
412 Cannot control RPM during KOER high RPM check.
415 Idle Air Control system at maximum adaptive lower limit.
416 Idle Air Control system at upper adaptive learning limit.
452 Insufficient input from VSS.
453 Servo leaking down.
454 Servo leaking.
455 Insufficient RPM increase.
456 Insufficient RPM decrease.
457 Speed control command switch(s) circuit not functioning.
458 Speed control command switch(s) stuck/circuit grounded.
459 Speed control ground circuit open.
Jan 15, 2009 | 2001 Ford Windstar
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
49 people viewed this question
Top Robert Yick Co. Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
