Question about Symbol LS 2208 Barcode Scanner
It just stopped working
My scanner just stopped working. is there anything i can do to sort it out?
  • Anonymous Apr 08, 2008
    I have had 3 LS2208 Symbol Barcode Scanners just quit working after 2 weeks in service. I cannot imagine what the problem is.
My company installs ls2208s for our customers. Never had a problem until recently, one of our customers had three fail all at once. Upon calling Symbol (1-800-653-5350) I was told that there was "a bad batch." Apparently, wands manufactured around the end of Oct until Nov 2008 are bad. The company will replace the wands free of charge(make sure you save the stand and power cable as they will only replace the wand itself).
The manufacture date is on the label just above the trigger. Hope this helps.
Posted on May 08, 2009
    Problem Solver:
  • 13 Answers
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Posted on Sep 09, 2008
Hoe do I turn off my cash register it isn't working and it won't ring up anything
Did you sort out the problem?
I haven't worked with this model but one of the users has Royal cash register manuals here:
Aug 13, 2013 | Royal 14509 X Alpha 583 Cx Cash Register...
Fujitsu fi 5900c i am getting an U8 error and it has new rollers, i cleaned the paper path, stacker is empty. is ther anything else that i can do?
Hi have you got this sorted?, also need to know the detail code, hold down the two paper thinkness buttons at the same time you wil get a detail code, let me know what that is and ill try to help, unless you have it sorted, Cheers
Jan 21, 2011 | Fujitsu fi-5900C Pass-Through Scanner
Scanner stopped working. Only one light is on on
you will probably have to get another scanner or have the lights replaced
Apr 08, 2010 | Metrologic Instruments 9520 Voyager
PSC2355 Error Scanner failure Turn power off then on but this does not sort problem
This is a problem in scanner section on your printer.You need to disassembly the printer and pull out the scanner section.Open the cover of scanner section and you'll see the mirrors inside.You need to clean the ash from these mirrors using cloth which leaves no hairs.
WARNING! If you don't have a technical skills don't try to do anything.
If this not help you need to replace the scanner section.
Nov 12, 2009 | HP PSC 2355 All-In-One InkJet Printer
Is kodak digital science 3520DP a sorting scanner
The Kodak 3500 scanner series is probably the best scanner ever made, but NO, it doesn't read anything! Think of it as a digital camera. It only takes pictures. All OCR, ICR, BAR Code, etc. has to be read by software. Your software looks at the images and pull any info that it has been designed to detect off of that image. Some older scanners had built in bar code and patch code reading, but more and more, the software now does it, usually in conjunction with a Kofax card in the PC.
May 26, 2008 | Kodak Digital Science 3520DP Path-Through...
Installing Canaon Scanner lide 25 works on one computer but not another
The problem was a 'corrupt file' with the computer.
that why scanner wouldn't install. There wasn't anything wrong with it, after all that.
I had to have everything removed & reinstalled (painful) computer melt-down, but it is all sorted
Apr 29, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
X1185 not scanning
my scanner was working the other night then i went to scna another pic and the white strip in side was up and down and it turned and now it is side ways and it wont move and makes a weird sound when i go to to use my scanner
Dec 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Scan head/carriage not parking in one spot -- keeps moving.
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
Dec 01, 2007 | HP LaserJet 3320mfp All-In-One Printer
Communication problem?
Dear CrysC,
I had the same problem with my HP Officejet J5780. I just got it to work with a different paper size.
Don't ask me why this worked, but it did, so I guess that's all that matters.
In Omnipage, I went under the "Tools" menu and clicked on "Options." I then clicked on the tab, "Scanner." I changed the paper size to what I wanted (A 4). I then clicked on "Setup." Despite its recommendations not to do so, I reinstalled my scanner.
After the reinstall, it is now scanning the new paper size.
I hope that I don't have to do this everytime I scan a new paper size...
Douglas1966
Aug 28, 2007 | Canon DR-2580C Path-Through Scanner
Symbol LS 2208 Barcode Scanner Logo
458 people viewed this question
Top Symbol Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
