Question about Onkyo TX-DS575 Receiver
Surround mode When playing dvd's the receiver won't switch to dts or dolby digital, the display still says dolby pro logic, I am using the optical input
    Problem Solver:
  • 14 Answers
Have you turned it on from the dvd menu the easist way to tell if you have is there will be little speakers that light up on your amps screen (more than two) when the movie is playing (not The menu) Not all movies are encoded in DTS hopefully this helps
Posted on Apr 02, 2008
SOURCE:
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
How can i get the dts sound field to work. Shouldn't it automatically switch to that sound field. I have a samsung bluray dvd that hooked up to it.  The dolby pro logic and pro logic 2 indicator...
If you are playing media that has both dolby digital audio and dts audio, your player and your receiver will decode the first audio codec listed first by default unless you select it otherwise yourself. If your remote or receiver has an A.F.D. (auto format decode) button, press it until your display shows that the sound source is dolby digital or DTS, whichever sound mode it was you wanted when you started your DVD.
Dec 12, 2009 | Sony STR-DE597 Receiver
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
TX-SR304 AV receiver
If you put DVD with Dolby Digital soundtruck it will show on your TX-SR304 Dolby Digital mode, and if you have DVD with DTS mode it will show DTS
Jan 17, 2009 | Onkyo TX-SR304 Receiver
Samsung DVD-R155 will not play in Dolby Digital surround sound
You need to buy a digital coax cable Just 1 run out of player and into amp!
Dec 06, 2008 | Samsung DVD-R155
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Onkyo TX-DS575 Receiver Logo
129 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
