Question about Logitech Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758)
Gamepad wont work - Logitech Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758)
  • 1 more comment
  • diddlers Apr 18, 2008
    gamepad wont work when playing online flash games, any ideas?, settings maybe ??
  • spdy Aug 20, 2008
    game pad calibrates fine but click icon and puter says no device found
  • Anonymous Jan 23, 2009
    im tryin 2 play an fps with my controller but the analogs wont configure correctly
    Problem Solver:
  • 17 Answers
Game pad is need to install in to yr pc 1 u have to install drivner then u plug yr gamepad to usb pord
thnaks
jo_chinmay
Posted on Apr 02, 2008
Why wont my left analog stick work? it wont let me run on cod
try this:
1-try rettting COD's control layout back to default...you might have changed the layout 2-is this problem happening in other games as well? if it does, then we can consider taking the controller for repair 3-there is always ebay and amazon to get you a new controller 4-do you have a wireless or usb adapter to connect the xbox controller to the pc? in windows 7 you can use the gamepad as a gamepad and in "callibration settings" you can test the buttons
go get those killstreaks!
May 08, 2011 | Microsoft Xbox 360 Controller
What gamepad works for pc ver of modern warfare 2
XBOX 360 controllers work by default. In case of Logitech gamepads, download this easy setup and you're ready to go:
Call of Duty Modern Warfare 1 & 2 Rumblepad 2, Dual Action and Precision Gamepad Setup
Dec 29, 2009 | Video Game Consoles & Games
Logitech Cordless Rumblepad 2
You need to set up profiles to use this gamepad. I ve made several profiles. Most downloaded are Call of duty MW 1 & 2 and NFS Shift setups. Download them here if you need them:
COD 4 MW and COD 6 MW 2
NFS Shift
Oct 10, 2009 | Logitech Cordless Rumblepad 2 Vibration...
Gamepad to usb adapters?
The adapter is out there. I happened upon one a while back, and got a nice joystick to work with it (win2k).
I can't seem to get my gamepad pro grip to work though. I think I may have bad controllers.
Jun 25, 2009 | Gravis GamePad Pro Game Pad
LOGITECH RUMBLEPAD2 ON VISTA PC
You can start from OPTIONS in the main menu of any game and then choose CONTROLS. There if you have both the options : keyboard/gamepad, then only you can use the gamepad.
Then if you have the Gamepad option there, then select it and configure/assign the gamepad keys for your game. You can do it by going onto an option; lets say ACTION and then click the Gamepad key you want to assign. Hold down that Gamepad key and double click the mouse. There you go.Your Gamepad is up and running for your game.
Cheers.
May 04, 2009 | Logitech Rumblepad 2 Game Pad
Mad catz gamepad for ps3 wont work..help
On Most Models They Will Work When You Hit The Reset Button On The Bottom Of The Receiver.
Feb 04, 2009 | Mad Catz PS3 WIRED GAMEPAD
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Dekcell gamepad won't work for PC
return it and buy a gamepad that works (doesn't ****)
Nov 04, 2007 | DekCell (CPA-1040)
Logitech  Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758) Logo
498 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
