On the sides of my plasma screen there is static which is very annoying
  • 927 Answers
This is not normal or save, please contact your manufacture right away. THIS IS NOT SAFE. In the mean time you can your a/c grounds, and for all safety plug your electronic devices into a known surge protector.
Posted on Apr 02, 2008
My Samsung Plasma TV has vertical lines on it. Is there a way to test the unit myself without resorting to taking it in to a repair shop??Any ideas would be greatly appreciated!!
means the glue or rubber padding on the gold static conductors are coming unstuck at the top of the screen just under the top of the plastic frame or has dirt...maybe this video is helpful, also happens to all Plasma and LCD and computer Monitors, it's definitely not a Motherboard issue it is a simple annoying fix but a real pain to get too if you have the patience.
LCD TV Repair Secrets Vertical Lines on the Screen
Apr 26, 2017 | Samsung Televison & Video
Green/ red pixels on screen. tv making annoying
If the unit has not previously had the PSU or Y-SUS boards replaced prior to this issue. Then it sounds like the voltages are off on one of those two boards. There is a process for checking those voltages and trying to adjust them. If those boards were recently replaced I would say the tech did not check voltage accuracy. But if it just happened out of no where go with the Y-SUS board as the problem. I say that because the unit powers on.
Feb 20, 2010 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
Whats the difference between a LCD and plasma
Answer: Outward appearances are definitely deceiving when it comes to LCD and Plasma televisions. Although both types of televisions are flat and thin, they employ different technology in an attempt to deliver similar results. Plasma TV Overview Plasma television technology is based loosely on the fluorescent light bulb. The display itself consists of cells. Within each cell two glass panels are separated by a narrow gap in which neon-xenon gas is injected and sealed in plasma form during the manufacturing process. The gas is electrically charged at specific intervals when the Plasma set is in use. The charged gas then strikes red, green, and blue phosphors, thus creating a television image. Each group of red, green, and blue phosphors is called a pixel (picture element). Although Plasma television technology eliminate the need for the bulky picture tube and electron beam scanning of traditional televisions, because it still employs the burning of phosphors to generate an image, Plasma televisions still suffer from some of the drawbacks of traditional televisions, such as heat generation and screen-burn of static images. LCD TV Overview LCD televisions, on the other hand, use a different technology (see also question #1 for this same explanation). Basically, LCD panels are made of two layers of transparent material, which are polarized, and are "glued" together. One of the layers is coated with a special polymer that holds the individual liquid crystals. Current is then passed through individual crystals, which allow the crystals to pass or block light to create images. LCD crystals do not produce their own light, so an external light source, such as florescent bulb is needed for the image created by the LCD to become visible to the viewer. Unlike standard CRT and Plasma televisions, since there are no phosphors that light up, less power is needed for operation and the light source in an LCD television generates less heat than a Plasma or traditional television. Also, because of the nature of LCD technology, there is no radiation emitted from the screen itself. Plasma vs LCD The ADVANTAGES of Plasma over LCD are: 1. Larger screen size availability. 2. Better contrast ratio and ability to render deeper blacks. 3. Better color accuracy and saturation. 4. Better motion tracking (little or no motion lag in fast moving images). The DISADVANTAGES of Plasma vs LCD include: 1. Plasma TVs are more susceptible to burn-in of static images. 2. Plasma TVs generate more heat than LCDs, due to the need to light of phosphors to create the images. 3. Does not perform as well at higher altitudes. 4. Potentially shorter display life span - this used to be the case. Early Plasmas had 30,000 hours or 8 hrs of viewing a day for 9 years, which was less than LCD. However, screen life span has now improved and 60,000 hour life span rating are now common, with some sets rated as high as 100,000 hours, due to technology improvements. LCD television ADVANTAGES over Plasma include: 1. No burn-in of static images. 2. Cooler running temperature. 3. No high altitude use issues. 4. Increased image brightness over Plasma. 5. Lighter weight (when comparing same screen sizes) than Plasma counterparts. 6. Longer display life used to be a factor, but now LCD and Plasma sets both have at least 60,000 hour or higher lifespans. DISADVANTAGES of LCD vs Plasma televisions include: 1. Lower contrast ratio, not as good rendering deep blacks. 2. Not as good at tracking motion (fast moving objects may exhibit lag artifacts) - However, this is improving with the recent implementation of 120Hz screen refresh rates and 240Hz processing in higher-end LCD sets. 3. Not as common in large screen sizes above 42-inches as Plasma. However, the number is growing fast, with 46 and 47-inch screen sizes becoming more common, and some LCD sets having a screen size as large as 65-inches also available to the general public. 4. Although LCD televisions do not suffer from burn-in susceptibility, it is possible that individual pixels on an LCD televisions can burn out, causing small, visible, black or white dots to appear on the screen. Individual pixels cannot be repaired, the whole screen would need to be replaced at that point, if the individual pixel burnout becomes annoying to you. 5. LCD televisions are typically more expensive than equivalent-sized Plasma televisions (although this is changing), especially when comparing EDTV Plasmas to HDTV-LCD Televisions. For a more detailed look at the LCD and Plasma comparison, check out: Should I Buy an LCD or Plasma Television?
Jan 18, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Viore 42'' Plasma, static in picture
Try a new Tcon board, most video issues are caused by this board.
Nov 14, 2017 | Televison & Video
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips Plasma Picture Way Off Center & A Static Line Appears
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Jun 03, 2017 | Televison & Video
Plasma HD TV Picture blue color static
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 02, 2017 | Televison & Video
Plasma tv only 18mts old has appeared with 3 green lines down the screen
I would check and see what the warranty is on this unit. It is either going to be a driver board issue such as a bad connection or a bad board itself. The other and most expensive issue could be the plasma panel itself which usually cost more than the set did originally.
Apr 15, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
