Can't get out of the hd zoom mode - Televison & Video
  • 927 Answers
Your problem may be an adjustment. Try your tv's remote zoom, but it's prob your cable/sat remote. Look at bottom right side of recon, hand remote. If not try resetting tv and or box.
Posted on Apr 02, 2008
SOURCE:
In Chile just bought a camera Lumix DMC FZ70, zooming only works in automatic mode AI in the other modes only works zoom 1 to 3x, please indicate what should I do
First thing Ariel is to read the manual. Specs say it has something called 'Intelligent Zoom', so it might be by design.
Panasonic Lumix DMC-FZ70 / DMC-FZ72 Key Features:
  • 16.1-Megapixel 1/2.3" High Sensitivity MOS sensor
  • LEICA DC VARIO DC 60x (20-1,200mm) Ultra Wide-angle Zoom Lens
  • 120x Intelligent Zoom
  • POWER O.I.S. (Optical Image Stabilizer) with Active Mode
  • LSI Venus Engine Image Processor
  • 3.0-inch 460k-dot Intelligent LCD Display
  • 0.2-inch 202K-dot EVF (Electronic Viewfinder)
  • 1,920 x 1,080 60i Full HD Video Recording with AVCHD (MPEG-4 / H.264) Format or 30p in MP4 with the Dolby Digital
  • Built-In Wind Shield Zoom Microphone
  • Up to 9 fps continuous shooting
  • ISO up to 6400
  • RAW file recording
  • P/A/S/M Full Manual Control
  • iA (Intelligent Auto) / iA Plus Mode
  • Creative Panorama
  • Creative Control
  • Creative Retouch
  • Creative Video Mode
  • HDR (High Dynamic Range) mode
  • 3D Photo mode
  • Optional DMW-LT55 Tele Conversion Lens extends the zoom ratio to 1.7x to pull the subject far off even closer with minimum deterioration of image quality.
  • Optional DMW-LC55 Close-up Lens
    http://panasonic.ca/viewing/ALL/DMC-FZ70P/OI/vqt5b59-eng/vqt5b59-eng.pdf
Jul 04, 2016 | Panasonic Lumix DMC-FZ70 Digital Camera
Screen is in undefined mode
Something like that might happen if you've selected a "zoomed in" setting and it only applies to HD channels versus classic 4:3 channels and you're going through different formats.
I do not know the settings on this particular TV by heart, but I've early HDTV releases struggle with that.
The other alternative is a bad main board.
I'd go to settings first and I'd also check if the problem is not showing only on certain channels (mostly HD versus classic format).
Mar 07, 2014 | Sanyo DP50747 50 in. Plasma TV
Over size picture jvc tv model tv20n33
Hello: THis model does not come up any where,recheck model. Also if using cable box and television has HD capabality then you may be in Zoom mode. Check you remote for a format button sound like like ur in zoom mode.
Oct 22, 2009 | JVC C-13911 13" TV
The ticker tape or lower banner is not visible on HD channels
It sounds like the TV is in overscan mode, thus chopping off part of the screen. Check your manual to see how you can change this mode. The mode also might be in 'Zoom', thus chopping off part of your picture
Feb 07, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Image too big for screen
I have the same tv.
On your remote push menu, then go to settings, and then screen. Put the auto wide to on. And keep the picture mode on normal, not the zoom or wide zoom. If its in HD it will fit the screen. If its not in HD it will crop the sides. This worked for me, hope it works out.
Dec 03, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have two Sharp Flat Screen TV model # LC-26SB14U. One is hooked up to a regular Dish Network HD receiver. The other is hooked up to a HD DVR receiver. Both are hooked up to the same Phillips DVD player....
if you using the component input on both tvs I will check the settings on the receivers, "HD setup", the difference is because the settings are set one on 480i and the other on 1080i
Dec 02, 2008 | Sharp Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Enlarged picture
Maybe it isn't the player, but the Aspect button on your tv remote.. Try it. The TV may be in Zoom mode, most new tvs have it.
Aug 17, 2007 | Protron PD-DVR100 DVD Recorder
Cant see all of screen
You should have a button or setting on the remote that says "picture size" or "aspect". One of those is set too "zoom" mode which will cut off the bottom and top of the frames. You want it to be in 16:9,Normal or Full mode (or whatever your set call it) to get the correct aspect. Or if you have a HD satellite rcvr. you might of placed it in the zoom mode as well.
Apr 25, 2007 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Ekse
