Question about Samsung HCN653W 65" Rear Projection Television
Same problem with my TV
I am having the same problem with my TV (same model as yours). When I turn it on, the Timer light blinks a few times but turns off. I can hear a click and it sounds like the TV is firing up but nothing happens. Is this similar to what you had? Also, I saw the part that you said fixed the problem. Did you install it yourself? If so, how difficult was it? If you hired someone, would you mind telling me what you paid them?
    Scholar:
  • 137 Answers
Hello jeber,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Posted on Jun 22, 2008
SOURCE:
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
I have a sony trinitron 27 in. model KV-27S45 1998 it will not turn on and the stand by timer is flasing 4 times dont know what to do
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
Mar 25, 2011 | Sony KV-27S45 27" TV
Hello, I have an 56' Mitsubishi 1080I television. Model #55859. We moved the TV across the room last night and now we cannot get it to turn on. All we can get is a flashing green timer light on the front,...
Hi rteague2566,
The flashing light indicates something is wrong. Have you tried pushing AV reset button on the front panel of the TV. You may even try the little pin hole reset by the power button too. I think you may have bumped or, vibrate it to hard in the move and, caused the lamp or lead wires to become lose or, unseated. You may have even damaged it. Did you move this TV when it was still warm? Is the light blinking fast and, can you hear anything going on inside. Usually the DM board fails or, a few capacitors need replaced with this model.
If you still can't get the TV to turn on after the reset buttons have been pushed. Can you read the blink code. It should blink, blink, pause, blink, blink, blink. That would be a blink code of 23. Count the blinks in between the pauses. Let me know what code you get. If it just blinks real fast it is probably the DM. I kind of think you may just need to re-solder the leads. A DM cost about $250 with labor. When you plug back in and turn the TV on, let it blink for a few minutes, it might come back on. I'll wait for your response to give further instructions.
Jan 26, 2011 | Televison & Video
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Feb 23, 2010 | Toshiba 42HL196 42 in. LCD HDTV
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Samsung HCN653W 65" Rear Projection Television Logo
126 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
