Question about Kitchen Ranges
Simpson double oven la stella model. fan thermowave function not working. all other stove fuctions working ok
ngfam1
  • 639 Answers
SOURCE: Atlas La Stella double oven
Hello Roland,
happy to help you out!
You must clean by way of wiping excess spills and materials dripped or spilled before self clean is operated. Or there will be smoke even during the self clean process!
Also do not wait till there is build up galore to self clean your oven!
If you spill or splatted and drip in the oven that day,
start the self clean after you do the dinner dishes!
More info can be found int he owners manual!
Posted on Aug 24, 2008
SOURCE: need to set clock on
I have lost instructions and need to set the display (clock) as it was turned off
accidently
Posted on Oct 12, 2008
SOURCE: Simpson Atlas Apollo ceramic top
Hello, I think I have the same oven as you, and yes the oven doesn't seem to work unless the clock has been set.
On my oven, there are 4 buttons and a dial below the digital clock.
To set the clock, you need to turn the dial whilst holding any two of the 4 buttons down.
For me it's a two handed job.
Cheers,
Michael
Posted on Dec 07, 2008
SOURCE: Simpson harmony nova oven ,
I had same problem. Replaced fan motor,really easy,but still would not turn. Got my brother inlaw to check it. Turns out it was the thermostat. He gave the connections a cleanup with sand paper, like you do car spark plugs. Works great,
Posted on Apr 21, 2009
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
How do I remove the door on a simpson la stella wall oven to make cleaning easier
go to your authorized service agent and ask for a parts diagram for the door hinges
that will show small locks that when the door is open can be rotated into the slots of the hinges and lock the hinges open
from there you lift the door up and out of the hinge slots
Jun 08, 2017 | Ovens
Simpson Model la Stella Oven Thermowave not working Fan works and other settings OK
Burnt out element , thermostat or switch, test with meter.
Nov 10, 2016 | Ovens
Need a manual for Simpson Ezi Set Upright GAS Oven/Stove. Think the Model No. is 62F851W. The stove top has 4 burners. There is a griller in the oven. The griller and oven have piezo(?) ignition. ...
Thank you I have contacted simpson directly to obtain your manual from the manufacturer I will look for there response tommorow and message you my contact mail information when it is sent from them. And if you have to use a match on top to light the burners you would first assure that you have spark if you have no spark then you would look at the spark modulator which is what most stoves use to send the current to the electrodes to create the spark. If you did have spark you would then need to check each electrode or ignitor to assure that they were not cracked and they were functioning properly. If you have any questions message me back or I will be posting as soon as simpson responds to my contact of them.
Thank you
Rick
Dec 07, 2011 | Refrigerators
Oven fan not working
If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
Feb 25, 2011 | Stoves 720EF Electric Double Oven
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Apr 30, 2010 | Stoves 720EF Electric Double Oven
Can not set clock on Simpson La Stella oven
How do i set the time on a Simpson La Scala wal oven
Jun 30, 2009 | Electrolux Ovens
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Kitchen Ranges Logo
380 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
