$$$$ fixed I have a Vizio P42 hdtv type SP42 When tv is on you can see 5 wide horizontal ( red,white,black,blue & green ) color. are rooling one by one and my front power,menu,volume and channel buttons also do not work, my question is, sombady can fix, it's property or not, thank you.
I had the same horz. lines in my t.v. I called everywhere and ended up fixing it myself.(The solution on my t.v. was to unplug the set hold in both channel buttons and plug the set in at the same time you hold the buttons) it then reset the t.v. lots of luck.Bob p.s let me know if it helped you.
Posted on Apr 30, 2008
  • young_dale25 Sep 23, 2010
  • 1,226 Answers
There is a problem in the horizontal projection of your HDTV. You need to open the back of the TV to troubleshoot errors horizontal back panel. if affraid to do so you can contact the vendor of the HDTV or the service center nearest to your location.
Posted on Apr 02, 2008
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
Apr 25, 2014 - Uploaded by
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
What colors are the wires for the pwr sw, smi,rst,hdd led,grn led and where so i plug them in at s7sen 15-a01-013010 rev 3.0a
- the colors of the wires (can differ, depends on the case type):
  • Green(+ is the colored wire)-White(-) --> POWER LED (GREEN light)
  • Red-Black -> POWER SWITCH
  • Red-White -> HDD LED (RED light)
  • Blue-White -> RESET
  • Red-Black (4 pins wide)-> SPEAKER
Sep 03, 2010 | EliteGroup K7SEM Motherboard
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
My Vizio has no green color. Other color are very
What type of connection are you using? if you're using component, make sure all the red, blue and green matches. If all is correct, go to menu, picture and all your color setting is there
Jun 10, 2009 | Vizio L32 32 in. LCD HDTV
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vizio P42 model Sp42 A
I had the same problem. I bought the TV with the same symptoms and couldn't find a solution. So just on a hunch I tried different button combinations on the front of the TV while I turned the main power switch on in the rear. One I got to the Channel up and Channel down the TV came to life and works great. So just hold those 2 buttons down at the same time while you flip the switch on the back. Hold them for about 10 seconds and then you should be good to go.
Apr 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
