Question about Uniden BC60XLT Handheld Scanner
I WAS ON ONCE AND THE ATTENDANT ENDED THE SESSION IN THE 1ST SEC AND i NEED HELP
I NEED THE PROGRAMMING FREQUENCIES AND DSO NOT KNOW HOW TO PROGRam them myself and lost the booklet! I am quite angry that the last attendant ended the session without even helping or asking queations
    Brigadier General:
  • 6,966 Answers
Hi again Anarexa,
I am not privy to the information who the first support person was that responded to your Live Session. But you can email Fixya at General Support - [email protected] and relate the incident. Am quite certain your concern will be attended to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 02, 2008
6ya staff
SOURCE:
Hi I have a vertex vx2100 radio and I need to know if I can use it as a police radio scanner
Yes. The Vertex VX2100 is a VHF radio which can be programmed to frequencies between 134-174 MHz. You would need to program in the frequencies you are wanting to scan as receive only (no transmit) into the 8 channels of the radio. You would need to acquire the frequencies you need, as well as programming equipment, or take the radio to a dealer for programming.
Best regards.
Mar 31, 2014 | Vertex Radio Communications
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
We have Panasonic TES 824. We connected 3-direct lines, one of them is for fax. However if I call the fax number, it goes to auto attendant. How to disconnect the fax number from auto attendant? Awaiting...
By programming. If the Auto Attendant is the DISA card, you can tell it to listen for the FAX tone and transfer it to the fax extension, or, you can program the 3rd number to ring only the fax extension and no others. Both require programming in the system cabinet.
Carl
Jan 18, 2011 | Panasonic KX-TA824PK Phone
How do I change the time on my Panasonic KX-T7736 phone?
The time can be set through system admin programming at an extension that has been allowed this ability, usually the attendant phone. To access system admin programming press <program> **1234(1234 is the default password). Once in programming dial 000 for time/date. Use the LCD navigation keys or the jog dial to scroll through the date to get to the time, after setting the time press <enter> to save the new time then lift handset to end programming session.
Dec 08, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
I can't changed name on my phone. please help me.
The extension names can be changed in admin programming from a predesignated programming phone. Typically this phone is the attendant phone as in ext 100 or ext 101.This phone needs to have an LCD screen.
1) Press <program>
2) Dial **1234(1234 is the default admin password)
3) Dial 004 for Ext name programming
4) Press <enter>
5) Dial extension number that you want to change name of as in 102
6) Enter name (20 characters or less )
7) Press <enter> to store
8) Press <end> or lift handset and return to cradle to end programming session
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
How do you find someone to program a Bearcat scanner?
The 370 is a straightforward scanner and fairly simple to set up, and you should be able to program it yourself with no problems.
Your first step is to make a list of the frequencies that you want to program. Your scanner has the capacity to hold up to 300 frequencies, so you should probably write out a list or type it up in your computer. There's an area in the scanner operating manual for listing your frequencies, but it doesn't have space for you to list the users. You can find a comprehensive database of active frequencies in your area by visiting:
www.RadioReference.com
Once you have your list,
1. Power the scanner ON.
2. Press the E/PGM key to enter the programming mode.
3. If the displayed channel is not the one you want to program, enter the desired channel number and then press HOLD.
4. Enter the desired frequency - including the decimal point.
5. Press E/PGM to enter your data into the scanner's memory.
6. To program the next channel, press the UP or DOWN arrow key, and then start again with step 4 above.
7. To exit the programming mode, press the HOLD and SCAN keys.
The scanner operating manual contains more detailed programming instructions, along with information on how to use features like SEARCH, Weather Alerts, and Band Search. If you don't already have a copy of the manual, you can download and print it here:
http://www.uniden.com/pdf/BC370CRSom.pdf
If you run into any problems while programming, just let us know.
Bill B
Jul 01, 2010 | Uniden BC370CRS Base Scanner
Programming auto attendant on partner II
The extensions in the voicemail group are not programmed. You need to put the ports that the system sees the voicemail, into #505, group 7.
Apr 10, 2010 | Avaya Corded Phone avaparp18d
Programmimg help
The BC72XLT is a fairly simple unit to program, but you will first need to know what frequencies to put into it. You can find active frequencies for your area by visiting RadioReference.com or CityFreq.com. Below is a link to the manual for your scanner. It will walk you through the programming steps.
http://www.uniden.com/pdf/BC72XLTom.pdf
Nov 20, 2009 | Uniden BC72XLT Handheld Scanner
Programming pro 106 scanner
Your scanner covers conventional frequencies as well as a variety of trunking systems. Programming steps can be detailed, and they vary according to the system being worked, so it's not practical to attempt a full programming tutorial in this short response. Your best bet is to review the operating manual for the scanner, and then follow the steps for the system(s) that you want to program. If you run into a specific problem, let us know and we'll do our best to work through it with you.
Need the manual? You can download/print it here:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000106_PM_EN.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
Aug 23, 2009 | Uniden BR330T Handheld Scanner
Programming assistance needed
What aspect of programming do you need help with? Do you need the frequencies or just a place to program them?
Nov 29, 2007 | Radio Communications
Uniden BC60XLT Handheld Scanner Logo
51 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
