Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Door display freaking out
Apparantly, same problem as everyone else. Door lights freaking out, ice flapper won't stop opening and closing...lost all of food in freezer.
Ice maker has NEVER worked correctly....don't even use it. However, the display controls everything on the fridge including the temperature....therefore, my food is melting.
I basically own a $2,800 ice chest. What a piece of cr_p!!!!
Chris DeWitte
[email protected]
  • 6 more comments
  • swsally Apr 06, 2008
    same problem - door display and ice flap freaking out.
  • ken in ny Apr 07, 2008
    same problem just call maytag and they will send you the part and have a service person instal it at there cost
  • dansalmo Apr 14, 2008
    I have the exact same problem. It seems to happen only when the compressor is running.
    Mine is 2 years old and had a the same board replaced about a year ago. I love the fridge in any other way, but this sounds like an issue that is not just a random failure. I am going to ask them to repair it for free. Will let you all know what happens.
  • dansalmo Apr 15, 2008
    Called Maytag directly (not the A&E service) and they are sending me a new HV board even though my fridge was out of waranty. They are also sending a repair man out to install the board after it arrives.
    I was able to stop the clapping noise by stuffing a paper towel up into the ice flapper when it was open, then the frdige was usable until I fixed it.
    Found these instructions on how to fix it yourself. It worked. I did it anyway just to not have to wait for the new board to get my fridge back in working order.
    http://www.liny.net/MaytagIce2O.htm
  • DedeV Apr 18, 2008
    I have the same problem. The display is flashing and going crazy and the ice door flapper is opening and closing.
  • Anonymous May 20, 2008
    same problem. Frig was working fine- made ice and dispensed water.
    Just heard a noise and saw the lights blinking. Tried unplugging a re-plugging - it did not work
  • Anonymous May 27, 2008
    Came home yesterday to find door controls flashing and immediately googled it--glad I found you all!
    I've owned it a year and when I called today they immediately apologized and set up an appointment for a service person from my area to come out and fix it. It's Tuesday now, and the appointment is for Thursday, so I'm moving everything out of my freezer, but otherwise am satisfied.
    The company was really quick to respond, so all the calls have made a big difference!
  • Anonymous Jul 22, 2008
    Same problem , new fridge only 12 month old
    litghs friking out , and ice flaper open and close
    i disconected the power but didn't help
I am experiencing this flap/display freakout, and I went to the page w/ the DIY fix
I'm not doing the whole repair, but I did nick his tip to remove the left plastic door hinge cover and disconnect the wires. Made it stop while I booked repair.
One other note: be sure to empty out your ice tray if this happens; the time that the flap spent opening and closing likely melted your ice. If it re-freezes around the corkscrew dispenser, I think that would be trouble.
Posted on May 19, 2008
  • 26 Answers
Very common, this unit was mfg by samsung for ge and maytag. Its your hi voltage control board located on the back. You might call maytag and see if they will pick up the costs for this repair. There was recently a major rework kit for the samsung and ge units, but maytag opted not to follow the same. Call them and raise heck and let them know your food costs that spoiled and that your afraid to touch it because of the actions of this ele problem.. G luck
Posted on Apr 02, 2008
SOURCE:
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
Flap for ice dispenser won't close
ok you have to replaced the flapper (door recess asm) here is the part no. WR17X3093 makle sure to defrost all ice or snow around the flapper and replace it with the new one
Aug 04, 2011 | Hotpoint HSS25GFP Side by Side...
Why does water dispenser stop working? Seems to work fine after thawing freezer for about a day and seems to freeze up. Water line for dispenser routes through the door.
The water is door spigot can be freezing up if the ice door is stuck open. When you actuate your ice in door function you hear a solenoid CLICK. That solenoid is supposed to open the ice door flapper. If the flapper is not funtioning correctly (stuck open) then in as few as as 2 - 3 days your water in door can freeze again. If you want unit specific information we need your make and model number to better help you.
Thanks for hoosing FixYa,
Kelly
Feb 22, 2011 | GE Refrigerators
The ice cube maker makes ice ok but the ice crusher is not crushing properly. The grinder area(teeth) seems to keep geting frozen (clogged) with ice.
The most common problem with this is the door/flapper is not closing snuggly. Usually a piece of ice holds it open but if this is happening all the time make sure the little ice door/flapper is closing all the way open the door and push it open and see how it is closing. If there is not water freezing on the left side of the freezer under the icemaker its self you have to have air getting into the freezer and usually its the ice door. good luck
Aug 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Helo I have a KitchenAid KSBS25FKWHOO which is like this one. My problem is there is a push button for ice cubes or crushed ice and as of now no matter which button i push it gives crushed ice. How can I...
It sounds like your crushed ice flapper might be stuck.
Open the freezer and remove the ice bin by pulling toward you. Dump the ice into a container if you wish to save it.
Turn the bin upside down and look at the opening in the front that the ice drops out. There is a white flapper door that is controlled by a metal rod going all the way to the back of the ice bin. If you move the metal arm up and down from the back you should see the flapper door open and close. Open is for cubed ice and closed causes the cubes to travel through the blades and be crushed.
The most common failure is ice or frost build up around the flapper door that causes it to stick shut and not move to the open or cubed position. You can unthaw by running warm water through it in the sink. Dry completely before returning it to the freezer. Clean out any ice chunks from the chute in the door that might be slowing down ice. That should fix the problem.
Apr 18, 2010 | KitchenAid KSBS25IN Side by Side...
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Kenmore side by side icemaker
Your product is an IDI (In Door Ice the bucket is in the door) or a Non-IDI? By the way, you mention the Ice maker. The thing is that if the ice maker is not runnning then you don't have ice to dispense and obviously the fact that the motor is working or not is irrelevant. So that's why I suppose that the problem is not the ice maker but the trajectory of the cubes from the bucket to outside of the door.
In the Non-IDI sometimes it happens that the safes in the bucket jump the locks were the bucket resides so the auger motor (the one that move the shaft so you get the Ice) is still running but you can't get ice because the bucket is not in the right position. Just try to relocate the bucket.
You can see if the motor is moving the shaft pressing the light switch that is at the top of the freezer. Then dispense, when you press the switch the main board thinks that the door is closed so you can dispense and see if the motor is moving the shaft.
Other failure mode is the flapper door, it depends if the dispenser works with full electronics or if it's an electromechanical dispenser. Full electronics dispenser use a stepper motor to move the flapper door so the failure is that when you press the pad and the flapper door is closing, if you press it again then it get stucked, the motor dispense but the flapper door is closed. With electromechanical dispenser, maybe is the dashpot mechanism.
If any of these solutions couldn't fix your problem please tell me. I think that I can solve this particular problem.
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice door flapper does not open
It is possible that the solenoid wire connections may have come loose.  You will have to pop off the front cover of the display panel to gain access to the solenoid.  To remove the panel, look below the bottom of the panel to find 2 screwdriver holes.  Slide a screwdriver in one of them and gently pry open the panel.
Aug 11, 2008 | LG LFX25960ST Stainless Steel French Door...
The control panel light blinking and ice trap door will not close
Sounds like you need a new display pwb. The flapper for the ice works on a solenoid which is on a little board that is behind the display board. When the power is cut the flapper should close as it is on a spring. I don't believe that there is any worries of it catching fire. Have a tech come and replace the board for you.
Sgt 48
Jun 03, 2008 | LG LFX25960ST Stainless Steel French Door...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
415 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
